I just found this in the rpi faq under vga output....
The 40 pin header model b+ (and I guess the Pi 2 as that also has a 40 pin header) can be tweaked to output vga signals over the gpio using a resistor ladder dac.
This means that you don't need to use a hdmi > vga conversion unit, BUT you loose most of the gpio pins.
So... this means that you need your game controls from else where such as the usb, or a usb > serial link such as I am using with the cannon board at the moment.
Here is the link to the document in the project hub....
https://github.com/fenlogic/vga666/blob/master/documents/vga_manual.pdf
buy here....
https://www.pi-supply.com/product/gert-vga-666-hardware-vga-raspberry-pi/?v=79cba1185463
http://www.raspberrypi-spy.co.uk/2015/01/introducing-the-gert-vga-666-adapter-for-raspberry-pi/
ColinD2016-01-25 21:21:35
buy here....
