rtype m72 board graphics
roger821
2CR
hi just got my old rtype board out to put into a cabinet .
upon testing it i find that graphics are missing, the ship is missing and on startup the rtype logo as also gone.
after a few minutes it starts to re appear and slowly fades away again . i can see all the background and hear the sounds but no ship.
any advice would be appreciated .
cheers roger
Flinnster
The Dino King
29 (100%)
2,566CR
Pull out, clean and reseat the sprite gfx roms. Use mame to determine which chips they are rather than shotgunning the whole lot.
Monstermug
1,807CR
It will most likely be the sprites ram or related custom which is a weak point for m72 pcbs. U can confirm this by changing the middle board with another m72 middle board. Also on bootup is there any fault codes on self test? You could also try cleaning the extra power connectors if your revision has it.. it helps distribute the 5v across the other layers.
A good board including m72 will happily run under 4.8v - 5.v under load. Setting it to 5v at the jamma edge may likely fry it if u have a bad edge connector or forget to change the voltages back before plugging in a small pcb. One of the top pcbs killers imo.
In doubt best to send it to a professional rather than mess it up even more.. the pads on m72 pcbs are quite fragile.
roger821
2CR
cheers will have a good look at it and let you know how i get on with it thanks for the info
