Russ's Mini Cocktail Table
retromax
18CR
I didn't intend on doing this I was just in the attic the other day and found an old 15" Dell monitor which I de-cased and thought i'd put it to use
When I was buying the buttons for my Weenix cabinet I'd seen those flat-pack table-top cocktail tables and thought something like that may be some future project but not buying a kit just making from scratch, I wanted another raspberry pi project anyway so I had a look in the shed to see what scraps of wood I had left over then just got the jigsaw out
I must say that nothing I have done with this has been planned on paper or anything it's just been a case of drawing on bits of wood with a pencil and a ruler (with the odd washing detergent lid to draw an arc
), then once one piece was done I measured up and cut another piece to fit... nice n easy no stress or any real effort!.
When finished it's gonna be sprayed white with black t-moulding, black buttons and black joysticks, infact the black joysticks are nos black Electrocoin ones (the same as the little red ones found on most Electrocoin cabs but in black)
The t-moulding in the pictures is just some old stuff just temporary as i'm building it, I have some brand new stuff to put on after painting.
So it's been 2 days and here's where I am, I only have pictures starting from the end of the first day when it was pretty much taking shape as I just wanted to get on with it (the pictures on the brown rug).
The little mains lead is for the monitor
So that's where it is right now, the little legs are 150mm furniture legs from B&Q (£2.59 each)
Looking at it from the side... looks very Oriental... or is that just me?
Russ2016-10-22 20:07:46
retromax
18CR
When I was in b&q I was looking at some clear acrylic glazing sheets, no chance I was paying 36 quid for it though!, there was a smashed piece thought that I would be able to use for the top so I asked the guy if I'd be able to buy it he said yeah but it won't be much cheaper. Which piece he said? This one I replied... just a minute he said and disappeared then came back with a sticker and marked it down as scrap for £3
Russ2016-10-23 02:15:40
_Matt_
965CR
Go on admit it, you smashed it didn't you
retromax
18CR
Nah but that sounds like a plan
£3 definitely had the wife's approval though!
retromax
18CR
minwah said:
Nice work, I like it!
I think you stain the sides rather than paint, the woodgrain would look great!
Can't do as it's just scrap wood, the sides are some sort of veneered mdf with not much veneer left when sanded, plus there's filler on it too as I don't want any gaps. It's jus a mismatch of wood really I always seem to stain wood so I thought I would paint It for a change.
retromax
18CR
Little update
Also cut the clear acrylic for the top and tested the speaker grills in place prior to painting.
Gonna have to leave it for a few days now as i'm always too keen to reassemble stuff before the paint hardens.
Might have a look into the raspberry pi image next...
retromax
18CR
So this is what those holes on the side are for
The 2" Speaker grills were a couple of quid off ebay
I'm hacking a pair of Logitech Z-130 speakers for the sound
retromax
18CR
Well earlier this evening I discovered that the viewing angle on the dell monitor I have used is crap and you need to be facing it straight on and not at any angle whatsoever
2 more monitors down the line and moving on!
yeah I really ought to have checked that first I know so a minor setback and a bit of re jigging inside!
retromax
18CR
So after the monitor problems sorted I decided to start some wiring!
I've had an old ipac laying around for years and it's now been used
The speaker innards
Just a bit of tweaking with the raspberry pi to do really and all done!
Russ2016-10-30 13:44:25
