Safe to continue using supergun?
mrpitchy
6CR
I have just plugged in a jamma pcb to my vogatek mkiv through a jamma extension harness. I instantly noticed the picture was not showing followed by the smell of burning and smoke coming from the extension harness.
After turning everything off and making sure nothing had caught fire (luckily it was all okay) the brining seemed to come from a wire or wires on the extension harness. There is no burn damage to either the pcb or supergun.
I have since tried the pcb without the harness going straight into the supergun and all works fine. Though I only tried this briefly because I am worries of more damage.
Would this just be the extension harness wire and the supergun with its power supply are still safe to use? Or should I invest in a new supergun and power supply?
7,230CR
Happens a lot of the "Cheap" extension.
Dont plug a PCB in just Remove extension and test all voltages & test is all ok. Then test with a board.
P.S Half way through your adapter !! Will be done for tonight I will pm you later.
TheDaddy2020-08-02 16:50:22
mrpitchy
6CR
Don’t have a multimeter, but my retroelectronik supergun does I believe. Will test power supply on that. Or just switch to using that supergun always!
Thank you guys. And for working on the adapter Dave :)
Once I get this problem sorted will need help with another lol. Today will be a day of learning!
7,230CR
Monstermug said:
TheDaddy said:
Happens a lot of the "Cheap" extension. Superguns.
Agreed.
mrpitchy
6CR
The power supply is an old new stock atx with -5. Not been able to find a model number or make :(
For tonight I have put it all away and will consider my options tomorrow. Cannot test the power supply on my retroelectronik multimeter due to realising the vogatek takes 20 pin, and the retroelectronik is 24 pin.
Luckily the only board I’ve plugged in today is my cheapest one. Worst case scenario I lost 30 pounds as opposed to a Frogger or Pooyan board.
What non cheap superguns do people use? Same with power supplies? Tempted to invest in a quality set up. Where I can adjust the voltages. Many of the boards I play are pre-jamma which I have heard often need some tweaking with respect to voltage.
neo-geo-mvs
24 (100%)
934CR
I've bumped a supergun thread for you to read. I need to read through it myself as I wouldn't mind a new supergun with cps kick harness etc at some point
mrpitchy
6CR
Think I made some progress this morning.
Turns out the retroelectronik pro supergun is compatible with both 20 and 24 pin atx. So i tested the power supply i was using it on the inbuilt multimeter and got readings of 5.28v and 12.3v. To my knowledge this is on the higher end and am I right in thinking this could have caused the extension to burn?
My understanding (though limited) is that ideal voltages are between 5-5.1 and 12-12.1.
I have also tested the pcb with a new PSU I had spare and it works fine. Problem is the PSU has no -5v rail. And the auto generated -5v on the retroelectronik supergun is very low (limited to 1w I believe). This makes many games difficult to run for me. Pooyan for instance will have no sound with that PSU.
Considering my options which currently seem to be buying a atx with a -5 which will send voltages within the safe limit. Or the retroelectronik is also compatible with a arcade power supply. Granted I have no idea how to connect one of these!
mrpitchy2020-08-03 13:39:08
