Safety switches
Thefuzz73
27CR
Hi
I have a machine where all the white safety switch plungers are all wired to each other but dont operate to cut the power when I open any covers.
It seems somewhere they have been bypassed.
It appears some bodgery has been done at the incoming switch connection on the back of the cabinet.
I have found two tail ends that appear to be part of the switch circuit but aren’t connected to anything.
Where should the connection start and how should it be connected ?
Any help to re instate the operation would be appreciated.
Cheers in advance
69er
1,854CR
on many games with dedicated or manufacturers power supply units they often wire into a plug on the power unit ........... ATARI arll and HANTAREX US250 and others are typical but due to age and reliability and the chances games have been upgraded to other internal parts ........... the original bits may have been removed or changed ............
its purely a 'health and safety' thing to protect inexperienced engineers and owners from hazardous voltages .................... all you need is a meter to check all the switches function ON when held OFF when central and many have 3rd pull out position to power when doors are open for diagnostics etc.
they are just usually a series wired loop which when broken circuit at any one switch the live wire at the power source is isolated .............. you could just link them back in a loop patched to a live feed BUT BE SURE THAT ANY EXPOSED TERMINALS AT ACCESSIBLE DOOR SWITCHES ARE INSULATED and maybe shielded TO PREVENT TOUCHING A LIVE WHICH MIGHT EXIST ON THE SUPPLY SIDE OF ANY SWITCH TERMINALS
the long and short of this is if they have been bypassed due to reasons above ? and its in home use and working leave alone the 'sleeping dogs not to bite you with surprise'............ and ensure doors are always closed where children can access open rear or open fronts of equipment which may be on and unsupervised........ that may help perhaps? as many games don't have them fitted at all similarly with main OFF/ON switches on top or floor level side panels THESE WERE FOR THE PURPOSE OF TURNING ONE OFF INDEPENDANTLY when several were in a row on a wall of an arcade and the OFF switch could be accessed from the front save pulling away from wall to get to a hidden plug ( all pinballs have a mains switch under the right front leg as they were always in a row and nobody ever wanted crawl to the wall socket to turn them off) manufacturers realised this at an early stage especially with larger heavier machines in the late 70s/80s, and on ........
69er2020-12-24 15:12:48
