Good luck in your hunt, I've got a CVS hunchback which I took out of a table top to upgrade to a phoenix in the eighties. It was unused and stored for 30 years. Wired it up a couple of years ago and I had to replace both big ribbon cables( had to make them myself),almost all of the 2114 rams were bad a load of ls chips particularly the 244's I think. The EPROM legs had corroded so surgery needed there,also the sound circuit which I believe is in 2 sections(effects and music) had several dodgy caps and one of the amps (LM something) was blown.
I couldn't find schematics either but it had one graphics glitch when I put it in the to be finished later section. Since then I've realised my monitor a Hitachi CRT using a big chip to control synch etc had been faulty to a minor degree before the chip expired completely and have found since replacing it certain boards I thought were faulty are not, such as bad dudes,bomb jack booties,exerion so hunchback will have to come out again for another look.
As for people repairing these you'd need someone with an entire set up ,mine was working before storage and I'm in for 40 on quid in parts before any EPROM changes,what on earth happens to destroy the parts on these when not in use. I can understand corrosion on chip legs but the rest I don't know.
