is that blocks or just squasshed lines diagonal accross screen which is a bit too bright anyway (turn down screen volts or brightness) may be simple error especially if its different monitor perhaps??
if there appears movement in that image you have try tweaking the vertical / horizontal hold or phase adjust as it may just be a sync issue and the game is not presenting correctly .. if its blocks of garbage its perhaps more serious? get a better closer picture up and i am sure someone will be able help ?
