Scud Topper Connectors
Mr20to5
1,366CR
Hi guys.
Inspired by Terminator2k2 current thread found here and the great topper he has made for his racing cab, I have decided to make one of my own for my Scud sit down. I always have loads of MDF lying around, so might as well put it to use.
Because my racer is running the original hardware I would want to try and use the connectors that are already there, but as I have never used them or had a topper to compare against, I don’t know what each connector is for and what I could or couldn’t use.
Here’s a photo from the top of my cab;
20151115_194857_zpstxkkngyh.jpg~original
So, can I please ask for someone to tell me what each connector is for? I’m gonna guess that one is for the main lighting and the other for the “race leader” light? But I could be wrong……
Also, what kind of light could I use in my topper that I could then fit with a connector to fit this? I would like to use the easy option of LED strips but would this work?
Think that’s all, should be able to manage the rest. Thanks in advance.
Neil
Outrun2
Colonel Outrun
1,184CR
The 3 pin plug will be for the main marquee light - probably 100vac but you should check with a meter.
The 2 pin plug will be for race leader.
