Section-Z PCB repair
Purity
The Oracle
17 (100%)
2,999CR
I've been looking at a bootleg Section-Z PCB that I now have mostly working, but I'm stuck on the final hurdle, and was wondering if you could offer some advice?
When I got the PCB it didn't boot, so I checked the roms out and found one that was blank, so I replaced that with a re-burnt one.
The game still didn't boot, so I started to take a look at the z80. There are two z80's on the top board. One for the game and one for the sound.
I could see that there was no clock present on the CPU so started to look around where the crystal was.
Unfortunately there are no schematics for this board so it makes it really difficult to find problems :-(
Anyway it was determined that the clock was going through an LS04 hex inverter, and using a logic probe on that I determined that it didn't look right, so I piggy-backed with another and that gave me a clock, so I swapped that chip out.
I was now getting random garbage on screen, which was a good start. Next I looked at the reset pin on the z80 and it was stuck high on powerup. I traced that back to a 74LS14, and could see a 4.7uf capacitor, resistor and diode next to this LS14, which
I *thought* formed the reset circuit. So I did a quick check on the
cap with an in-circuit tester and it gave no reading.
Replaced the cap. It definately looked dead. No reading on my ESR meter. I only had a 3.3uf 25v so replaced it with that. Powered on, and got exactly the same. It was now time to take extreme measures so I cleanly desoldered the z80 and tested it on another board, and that board did not boot, so looked like a duff z80.
Popped a socket in, and stuck another working z80 on the board and the game now boots.
Problem I have now is that during my repair, a 1uf capacitor dropped off the PCB from somewhere :-(
Although the game boots and plays, some of the sprites have weird colours. Apart from that the sprites look ok. i.e. they don't look blocky or have missing parts.
So I've looked for the most obvious places that the capacitor could have come from but none make any difference to the colours.
As the sprite content looks correct, and I just have colour issues, do you think it is likely to be a problem just associated with that missing cap, or there is more to it?
Purity2014-06-19 23:34:31
enricnes
8CR
Hi, I think I have a section z boot too. Post hi-res pics of the boards and I'll compare with mine and maybe we can find out where the cap should go.
Cheers,
4,058CR
Have you considered that it could just be a difference between the bootleg board and an original? Or are you comparing it to make? In which case you should definitely be wary of assuming the board is at fault. Mame is certainly not always accurate in respect to colours and can even sometimes be too correct if that makes any sense at all!
0.1uF or even 1uF caps are more often than not just voltage filter caps.
VectorGlow
34 (100%)
900CR
I'm sure it's nothing to do with the cap.
If I had it on my workbench my first port of call would be the graphics ROMs/EPROMs and their sockets.
I'd then check out the colour-related RAM and logic and work through that part of the circuit.
I assume that the +5 volts is pretty spot on?
Purity
The Oracle
17 (100%)
2,999CR
Ok cheers guys, I'll continue looking to see if I can find the fault.
I know the roms which form these graphics so I'll look around there
The +5 volts is ok.
@Guddler - I am comparing the board to the bootleg rom in Mame
