Sega 16B Board
jonhughes
1,156CR
Hi everyone, I have a Golden Axe Sega 16B board that functions correctly other than some of the sounds are missing. I've narrowed it down to the screams or 'speech' for a better word for it.
This has led me to take a look at PD7759 chip on the board. Without circuit diagrams for this though I'm a little lost. So I've taken a known working board and measured the input values of the pins against the troubled board. Here's what I got for the worker.
1-3 pulsing logic.
4-11 generally in a low state.
12 pulsing.
13 low.
14 high.
15 low.
16 N/C (dead).
17-19 high.
20-21 low.
22 high.
23-24 pulsing logic.
25-34 N/C (dead).
35-39 pulsing logic.
40 high.
and for the trouble maker.
1-3 dead.
12 dead.
13 low.
14 high.
15 low.
16 N/C (dead).
17-19 high.
20-21 low.
22 high.
25-34 N/C (dead).
35-39 dead.
40 high.
I have trouble reading the data sheets for these things since there appears to be contradicting information for inputs and outputs. It's a place to start but is this appearing to be the likely culprit before I decide to pull it and swap it.
Cheers for any help.
RaveN
1,325CR
Nice find cmonkey, i've saved those!
jonhughes: looks like it is img018 you want to take a look at.
I would start off by looking at the LS244 at E18. Your /MD (pin 21) being low means the LS244 should be enabled and should be outputting your ASD lines to pins 1-3,35-39 (which you say are dead). Check the inputs/outputs on the LS244.
The /WR (pin 12) needs looking at as well, check pin 5 on the LS125 @ G20. If there's life there and your /MD (pin 21) is definitely low, then the LS125 is dead.
jonhughes
1,156CR
Magical, All inputs to the LS244 are firing away and all outputs are stone dead.
Thank you very much for the advice and I'll be ordering one of those in a couple of minutes.
Thank you again.
