Sega Card Reader ISSUE (Initial D)
Sbdesign
SEGA collector
16 (100%)
1,721CR
I have been scratching my head with this card reader.
The seller I purchased from had originally purchased as working, but didn't get chance to use it.
The seller has been spot on, but can not really advise on any help as never used it.
I had all the cables in my cab and got the initial task complete easily and up and running.
Was delighted when it printed my card first time - great
But when i went to read the card - error.
I did the R/W test in test, and it states ok.
Trying many times, it may read a card after 10-20 inserts but fail read or write when ejecting card after race. (some times read first time)
I managed to get sega cleaning cards, After running cleaning I managed to get a higher amount of reads/writes, but soon not reading again, and or writing (fails on read or sometimes write)
I've managed to load/save maybe 20 times in total, but attempted maybe hundreds. So at this stage it isn't something that can be used.
You can't race and build data, and have any confidence that it will save. And if it does, that it will read.
I only have 10 cards but speaking to a member about more.
CONCLUSION:
Both seller and I can only assume it is possible to get working. After all we have evidence it can read and it can write. But consistency is the issue
CAN THIS BE FIXED?
does anyone know if voltages can play a part?
Has anyone ever fully dismantled one of these to thorough clean? (I used the card to clean many times not just the once.)
Anyone understand what fails? I assume print is only for the owner to know whats on their card, and all data is magnetically stored. So its not the printer side of things thats an issue? Unless my presumption is wrong.
But I have reprinted over a card during testing, and it has managed to read it with text double printed - so I think that confirms that!
Any suggestions or help from another user would be appreciated.
SUMMARY
  • Got reader set up
  • Got ID2 cards x 10
  • Got sega cleaning cards
  • Done cleans
  • Had some read/writes
  • Fails most of the time
Sbdesign2020-03-12 11:03:06
Vamino
Insert coin(s)
2,700CR
There's a small psu that powers the card reader, think it's rated for 4.3a. When printing it uses more power.
Have you checked the voltages under load?
Sbdesign
SEGA collector
16 (100%)
1,721CR
Thanks for the input. I haven't and will.
The cab had the PSU, and one came with card reader, so I will check using the other PSU also.
Is this something you have witnessed causing a reading issue, or just a suggestion?
Do you use a card reader / emulated version with pi / or neither?
And if you do have a card reader... is it usually spot on? and has always been that way?
Vamino
Insert coin(s)
2,700CR
It's what I would be checking first, then I'd be checking the connectors that connect at the back of the coin tower, so many times spilt drinks can gunge up the connectors, then I'd be trying a different batch of cards and if none of those work I'd test a known working reader.
I sold my ID2 cab a few years back. I tried 3 card readers and they all worked fine, apart from one with a small bracket that was missing which worked when a new bracket was fitted. I never had any issues.
The thermal head printer draws more power when printing, so you could see what voltages it's pumping our at that stage. The psu can be replaced with a weaker one from a gun cab which I've heard can cause issues.
You can clone cards when the card has been accepted and is in the staged position. Open the rwader, insert a new card and when the game saves it will create a cloned card.
Are you sure your cards haven't been been near a magnetic field? Where did you get them from?
Vamino
Insert coin(s)
2,700CR
I'd you need cards I have some I could sell.
If you only have 1 reader I have one here as well, you can borrow it if you pay postage both ways.
Sbdesign
SEGA collector
16 (100%)
1,721CR
I'm going to try some of the suggestions today.
I had 10 cards, I think from ebay. I bought the cards and disc well before I got a cab.
They have been stored with me safely - but who knows.
My common sense was thinking if it read/write a few times in a row fine, they must be fine. But then it should all work and it doesn't so I think this go's beyond my common sense with these complications.
THANKS
I'd love to take you up on the offer, and borrow the reader...and cards.
Thats greatly appreciated, and would help massively.
I'll drop a message.
