Sega drive board error
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I am testing some boards and I am getting a drive board error decoder alarm in one of my project outrun 2 single cabs.
I have checked the wiring and tried a known working drive board so I know the wiring is fine.
Are these boards repairable or should I be looking to get another?
I have checked old posts and they suggest wiring but I know this is fine.
Any help would be good.
Thanks,
Steve
Outrun2
Colonel Outrun
1,181CR
Never had this error on any of my cabs but I know a bad connection will cause this. Although the wiring may look like it's all connected properly you can't really be sure unless you meter them for continuity. Sometimes the pins come away from the plugs on AMP and JST connectors so although the connector look good it might be just missing on one pin. Try pulling each connector off, inspecting and putting back in securely.
If a different drive board works fine in the same cab then you might have a faulty drive board. Only time I've had a FFB error on an OR2 cab I found pressing the small button on the drive board seemed to reset it and it worked fine after. No idea if this is indeed a 'reset' button, but it worked for me.
I imagine only Ken at irepairsega.com would touch these, other than Sega themselves and can't see it being cheap - it's why I keep spares.
bonehead
50 (100%)
1,729CR
It's the drive board that I am testing. I have tried it in my working outrun2 cab so I know the wiring is fine. I have tried pressing the reset button but no change.
I guess it could be a bad board as I tried it in both sides with the same results. Shame as I have 2 here that seem to be the same.
I will try cleaning the contacts on the boards and re try. Problem is it worked for around a minute or so then reported drive board error decoder alarm and then no force feedback.
More testing needs to be done I guess.
