sega megaplay pinout
madmax8
67CR
anyone with a working sega megaplay pcb? i need some help setting up the
second monitor. If i connect it in an original megatech cabinet which
have the same connections for megatech, i only get a picture on the
bottom screen. I looked around on the internet and the top screen should
give some information on how to play the game etc but it doesnt show
anything. I checked with someone else who has the same issue. Does it
need a strange connection or something to get the second screen working?
or is the megaplay pcb only compatible with 1 screen unlike the
megatech which outputs to 2 screens? if anyone has information on this
please let me know. I can't seem to find any information on the
internet, the manual doesnt say anything about the connections.
tb2000
3,584CR
Well it's normal jamma and I'm fairly sure it only uses one monitor. I have seen it mentioned here and there that it runs two monitors similar to the megatech but I'm not sure this is correct. I think that any megaplay cabs with two monitors are megatech cabs that have been updated with both monitors wired to display the game.
madmax8
67CR
as far as i know its an upgrade for the megatech.
It has all the same connectors as the megatech.
It has both connectors for both monitors.
They added a jamma edge connector to make it fit into generic cabs but it's designed to replace the megatech pcb. i can hook it up in the megatech cab with all megatech connectors only the second monitor doesnt work. Maybe it just gives no ouput on or i need to do a setting or the pcb is just broken maybe :)
