Sega Model 2 Board issue or something else
lix
546CR
I had a similar issue with my Touring Cars, in that the 3D graphics were rendering but physics wise everything was all over the place and it was unplayable.
It turned out to be corroded tracks between the TGPx4 math co-processors and their associated memory chips, which had been caused by a nearby leaking capacitor. I managed to largely repair the issue, wiring 20 odd wires from the top to the bottom of the board, but it was a lot of hassle and while it made the first couple of courses playable, the last course slows down to half the framerate on the second lap and you seemingly bump into phantom invisible cars, so there must be something I missed.
In the end I just bought another boardset, but I'm fully intending on re-capping all my Model 2 & 3 boards soon, to prevent any future issues!
Of course it may not be corrosion on your board. Could be a dry joint on one or more of the math chip legs, or a bad ram chip. Does the diagnostic test point out any bad ICs?
big10p
Coins detected in pocket!
6,093CR
Would seem to be an input issue with the board (or possibly whatever chip does the transformation and lighting calcs). Just be thankful you didn't buy a twin cab and discover one side plays Virtua Striker!
https://www.ebay.co.uk/itm/Sega-Virtua-Striker-Arcade-Boardset/222983232202?hash=item33ead61aca:g:DR0AAOSwPnNan~ie
big10p
6,093CR
Carvaletingpro said:
Thanks everyone for the input. that virtua striker was in the donor system im using.
Big10p will someone be able to fix this board set
Is that you selling the Virtua Striker on ebay, then?
Sorry, I don't know anything about these boards.
NaokiS
140CR
It depends whats bad. Traces, yes can be fixed. If the chips are bust, Beyond Economic Repair
Carvaletingpro
118CR
I bought the 2 cabs and tc board set from the guy selling the Virtua Striker
Outrun2
Colonel Outrun
1,184CR
Could well be the ROM board then - have you tried removing the ROM board, pressing the socketed ROMs in firmly and then re-installing the ROM board?
I was checking this on the Model 2 emulator earlier and couldn't replicate the issue so doubtful it's a pot out of calibration.
Carvaletingpro
118CR
ive got more info as i've sat on the cab today and played each car.
Is the rom board the entire board or just the top 1/2 board with all the socketed chips on.
Thanks for all the help
Outrun2
Colonel Outrun
1,184CR
It's the smaller, rectangular board on the top of the stack with all the socketed chips in..
http://www.system16.com/hardware.php?id=716
The board can flex when removed and lift the chips out slightly. Try firmly (but not brutally!) pressing them down one at a time. Put the back of the section of the board you are working on on a flat surface, like a wooden table, so as not to flex/stress the PCB.
I've cured issues with a few Model 3 boards doing this - it's not an exciting fix, but it's cheap and might just work!
Carvaletingpro
118CR
ok so i didnt take the board out but just pushed down a little on the roms and i now have the Merc also driving fine, but alfa and toyota play up. so i still might need to take the board out.
I also checked voltages whilst there and they are all over the place. some read 4.99v others at 0.59. could low power also be a factor here. i have all the voltages written down for each rom
