Sega model 2a/b/c test bench setup
Kev A
747CR
Thought I would post this up as it may be useful to others, its a pretty simple test bench setup for model 2a/b/c boards.
If I
was to do it again I would also include 3.3v on the power distribution
block, to be able to use it with model 3 boards, I did modify mine to
use with M3 but had to solder directly to the ATX wires as I had no more
room. Adding this was done by wiring 2 10 pin jst connectors one with 5v and gnd connections and another with 3.3v soldered to the orange 3.3 wires on the atx psu. But would recommend using the correct 24pin jst connector, mainly because when your in a hurry swapping boards over its possible to get mixed up and plug them in wrong.
Basically
it comprises of an ATX PSU that I pinched out of an old PC from work,
the Chinese CGA/EGA to VGA converter, a 2 channel amp, old speaker, and a
power distribution block I made from bolts and a bit of MDF.
The power cables from the 24 pin Molex connector on the PSU
were cut and attached to large ring terminals, These connect on the
underside of the distribution block and held in place with a nut. the
power cables connecting to the JST connectors go on the top side of the
board.
When I made mine I used 1mm wire to connect to the JST
pins, but this is much too large and means they have to be trimmed to
fit snugly in the connector pins, the spec sheet says 0.3mm max,
although I suspect you would get away with 0.5mm at a push if you have
some of that laying around.
The other thing to note is when I
initially made my setup I had three sets of power connectors for
powering M2A stacks (M2B only have 2) I pinched one set for my cab and
have only been using 2 for quite a while, although this may not be
recommended, as you wont be using the outputs on the filter board to
power other boards, I think its fine, and have never had a problem.
On
the ATX PSU, pin 16 needs to be attached to ground in order for it to
power on, I haven't, but it may be useful to attach an on/off button
here with pin 16 wired to ground the PSU is always on. I just turn mine
off at the wall, but again I would add one for convenience.
Also be aware some ATX psu's come with a little pot inside to adjust the +5v
it doesn't offer a great deal of adjustment like a JAMMA PSU but might
be useful if you can find one, I have searched online but it doesn't
seem like manufacturer's state weather PSU's have this or not, mine came
out of an old HP desktop from around 2010 ish.
Its all pretty
straightforward, about the only things I can imagine might cause
problems is the Sega wiring colours are opposite form the ATX standard,
IE Sega yellow is 5v and Atx 5v is Red.
Also I read (no Idea how
important it would be) that some high end gaming PSU's have separate
supply sections powering the motherboard via the 24pin molex and a
separate supply powering SATA etc. I just used molex for the board and
the sata connectors for the amp and video converter and just to be safe
kept them separate. although I'm 99.9% sure my little PSU all the power
sources come form the same section.
These are the JST connectors I used
JST NH, 2.5mm Pitch, 10 Way, 1 Row Female Connector Housing
JST NH, 2.5mm Pitch, 5 Way, 1 Row Female Connector Housing
JST NH, 2.5mm Pitch, 4 Way, 1 Row Female Connector Housing
JST Connector Pins
JST NH, SM Crimp Terminal Contact, Female, 0.08mm² to 0.3mm², 28AWG to 22AWG, Tin Plating
Anyway here are some pics and a diagram of how mine is wired up.....
Kev A
747CR
I have a few 4 and 5 pin jst connectors and a couple of 10 pin ones left over. If people might be interested I could order some more and divide them up and do little packs with everything needed.
