Sega Model 2B
simon_m74
Virtually real!
357CR
Hi all,
I have Inday 500 that is tempormental.
I have 2 other Model 2B boards - that currently dont boot.
Does anyone knmow what the array of 8 LED`s mean.
Red, Red, Red, Red
Red,Green,Red,Green
Both boards just light the line of 4 red LEDs, and do nothing else.
Ideas ?
simon_m74
Virtually real!
357CR
right.
I was using my bench PSU to power the boards for testing.
measured voltage - only 2.6 at board, so the PSU was not able to power the system well.
I up`d the voltage and ampage so that my meter read 4.8v (highest I got before the PSU cables started to smoke!)
At that point - 4 red went out, and 2 green on.... but no video out (although I do need to test my video cable)
With 2 green ( as well as the singular red on - on another part pf the board) - does that mean ok?
I`m going to take it to the Retro Computer Museum soon, and plug it in place of one of the Indy 500 boards - to see if it boots.
Mc-Q
1,450CR
i need to make an ATX to M2/3 loom this week,
if i get it done i'll document the led behaviour at the weekend.
not sure if i can crimp the jst's with what i have though!
channel27
1,377CR
I had my Sega test rig out this evening to check some Daytona boards and the Indy 500 I'd got last week was still to hand so I thought I'd plug it in and take a video of the LEDs.
I've no idea what the LEDs mean but here's it starting up and going into the attract sequence.
I assuming green / flashing green means good, but the reds change in sequence too?
(I wish I'd plugged the speakers in now because the music is fantastic :D)
channel27
1,377CR
The LEDs don’t change during either of the self tests. They pause however they were when the test button was pressed and only reset when exiting the menu.
simon_m74
Virtually real!
357CR
I have 2 working (ish) Indy 5000 machines.
Ish:
First: Doesnt always boot - sometimes first time, sometimes it just says `FREE PLAY` but noting else. When it does this it can take up to 6-8 reboots till it turns on properly.
Other: No Audio or Force Feedback - but currenlty the 240v>100/12.8v Transformer is being checked.
Either - will not network!
I`ve been working on the `third` indy board, to try to see if that helps the issues with the booting issue or maybe even the networking
Mc-Q
1,450CR
start with checking the psu - always.
if you have a scope - scope it.
if not, set your meter to AC and check the dc voltages - the meter will show the ripple(noise) that the capacitors are failing to catch.
simon_m74
Virtually real!
357CR
I put that (booting issue) board in the other machine to diag if it was the PSU or not - but the probel carried over to the other machine,
The one I tried it in is being powered by an ATX PSU.
