Sega Naomi monitor vibration
mx5dob
80CR
Hi all. Just hooked up a Naomi.to my jamma cab via a capcom i/o and I have screen vibration that I can't remove. I've tried adjusted the vertical hold on the monitor. Don't think focus will do anything as the image isn't blurry. Any ideas?
Paul
5,291CR
Looks like an interlacing issue. Is the monitor MTC9000? I had this problem but was able to tweak it away (mostly) as I was using a groovyMAME setup with CRTemudriver. No idea what to do with a Naomi, sorry.
gunblade
8,191CR
there is something else that may or may not help but is quick and cheap to prove, the hantarex can be picky with certain sync signals and to get them to display correctly in olden times we added a 5k resistor from v.sync to v.ground on the rgb connector
