I don't think anyone has ever really worked out what the LED lights on the board mean, with a working unit all the green lights flash randomly, im guessing as red 11 is on its own its just indicating the boards getting 5v.
I haven't seen a bad video board cause a stack not to boot (not to say its impossible) so I would say its likely to be either program roms, or the CPU board at fault, or a connection issue somewhere in the stack its self.
If it was me I would start by carefully reseating the 9 roms closest to the filter board (the ones the other side are graphics data)
If that don't help maybe think about removing the PCB stack from the cage and separating each board and reassembling making sure the connection between each board is nice and tight, and when you place the stack back in the cage make sure the pcb is pushed firmly up against the filter board.
