Sega restoration, help please
debilbao
3CR
Hi
I own a "megatech" and a "super video Sonic" labelled sega arcades, megatech cabinet is damaged by moisture and Wood is very weak, the other one is fairly well but need some cosmetic repair. In fact, cosmetics isn't the worst part, both arcades have been vandalized, almost cooper wires have been removed for scrap metal...
I'm really interested in restoration, i have in mind restore as original but i need wiring schematic for both. I think is a big business and really hard to do.
If that were not possible, my second choice is use mainboards on other cabinet but i'm really lost and need some help.
megatech isn't a jamma board, ¿can i plug it on a jamma cabinet? ¿what do i need to make it possible?
for second one, "super video", i don't have any info so, can i use on a jamma cabinet?
any help is welcomed.
thanks in advance.
strykr
1,351CR
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
for the mega tech you need 2 monitors
a 20 or 25 inch I think and a 10 inch for the menu
so a standard jamma cab would need loads of modification
and the super video is just a standard 20 inch jamma cab
Nes4life
1,134CR
Hey, a picture or two would really help. If you want to stick a megatech in a Jamma cab you'll need to make a harness. Obviously JAMMA doesn't support two monitors so you'll need to address that with a bypass for the second monitor. Does the board work completely?
stevebm1
39 (100%)
1,269CR
technically you don't need the top monitor to use the megatech board,you can still switch between games via a button on the cpo,you just won't be able to see the games list/info,but the actual games could be played on one monitor
debilbao
3CR
thanks for your answers, here is the link to imgurl album.
http://imgur.com/a/DvSox?gallery
I'll take better pictures and resize...debilbao2015-03-21 09:24:59
Nes4life
1,134CR
Looks like someone cut the wires! Atleast you've got the headers though.
Might be worth giving it a dust down.
Before you spend too much you probably need to hook up the power and see if the LED comes on. Then hook up a monitor and see if you get life out of it too. Obviously you need atleast 1 game. If it's dead then it's a long road to fixing these (not impossible though).
debilbao
3CR
I also have some games for testing, were removed to avoid loose them when i bring it home.
I've seen in other forum, that board can be connected to a tv by a jamma like adapter, may be i should make this adapter and check if mainboard is still working.
debilbao2015-03-21 16:11:46
Nes4life
1,134CR
Yep, make a jamma adapter for it... to test id do the following:
- visually inspect board for blown components. Pay close detail to resistors around the LED area.
- unscrew the daughter board and check for leaking battery (I've seen it corrode the tracks just above it towards the game cart edge which results in loss of sound tracks)
- check the underside that all the green wires are still attached properly. If you take a photo we can check that you have them all.
- check all removable chips are seated correctly
- connect up the 5v, 12v, GND lines on the power connector to a PSU
- observe LED lights when power switched on
- connect up RGB1 pins to a monitor (or SuperGun + TV if you have no arcade monitor)
- insert game
- turn on and observe game loading
- if nothing on screen then hook up RGB2 pint to the monitor instead
- observe game is detected in the slot
- if game is not detected in any slots then you'll see dashes in slots 1-6 and nothing in slots 7 & 8; this is a common fault and needs heavy investigation - just hope you don't have this issue)
- connect up player 1 controls and observe result in test mode
- connect up sound and observe sound
