sega scud ffb problem
Vamino
Insert coin(s)
2,700CR
Hi Neil,
I'm really not the best person to be asking to be honest, as a mere 5 months ago I couldn't tell my Japanese built machine's isolation transformer from the step down as you can see from this thread.
http://www.ukvac.com/forum/daytona-2-resurrection-restoration_topic337207.html
neil1637 said:
Vamino – you talk about taking anti-static precautions when cleaning the boards – please can I ask what these should be?
http://www.wikihow.com/Ground-Yourself-to-Avoid-Destroying-a-Computer-with-Electrostatic-Discharge
Now some people will scoff at the thought of static damaging their electronics, whilst other people will use hazmat suits, antistatic mats, rubber soled shoes, earth straps with a ground cable plugged into a switched off wall socket etc.
How you want to tackle the effects of static is your decision mate, the info is above and you can make your own decision.
neil1637 said:
You also talk about checking voltages – I fear this has gone way over my head. Do I need a multi-meter thingy for this, if I borrowed one could I use it (without killing myself!)? Would this help highlight where the fault lies, ie which board doesn’t have the power getting to it.
Yes, you need a multimeter. But as I explained above, I'm really not the best person to ask mate, I'm scared just by reading the language you use!
There is a right way and a wrong way, hopefully someone will chime in and explain/show you what the right way is. The voltage the components receive is very important, too low and there will be problems. And if voltages are too high there will also be problems which may not rear their head until it's too late, a side effect of prolonged high voltage is possible damage to the components.
Ensuring voltages are spot on will solve some problems, but again it's not a miracle cure. When the PSU is good, then you know what the problem isn't, it's all about eliminating what it isn't to find out what it is.
neil1637 said:
Then there’s the comments you make, Vamino, about the PSU and the problems built up crud can cause here, where is this please? What does it look like? How best to clean it (I’m guessing no dishwasher for this part)?
A dishwasher is not recommended to clean a PSU, there is a danger of electric shock when messing about with PSU's as the capacitor inside can hold a charge. Personally I use an Air duster (Canned air) and an old brush that uses natural fibers such as Horse hair.
But here are some pics of a PSU that was taken out of a Scud race:
PSU from my dismantled Scud race, there are 5 screws holding the top cover on.
The same PSU with the top cover off that I gave a quick clean.
The same PSU showing the 5v + 3.3v adjustment pots. When you are metering the voltage these are the pots you adjust to get the voltage bang on, over time they can and do require tweaking slightly.
neil1637 said:
As for the spare boards, I do intend to get some but absolutely strapped for cash just now with wedding only 7 weeks away just now, but would be nice to know what kind of prices I should be looking at for these, drive board/servo boards, etc?
I've paid 20 + postage for a servo board, and upwards of 35 for a control board. It all depends on who is selling tbh. Some people are givers and some people are takers, it's not unknown for helpful members to sell items at below market value just to help out a fellow hobbyist.
neil1637 said:
Anyway last question (remember you did say I could asking…), should I keep this thread running with my photo’s and updates, or start a new one under the Resto Forum. I intend to keep a detailed record and post it somewhere, as some of the ones I have found, posted previously, have been really helpful to myself, as I try to build up my knowledge.
As always, many thanks in advance and I hope to meet some of you in person at the big bash up North at the end of August.
Neil.
Mate, it's your thread! If you had a Vulcan mindwipe post what you feel will be helpful for yourself to reread as if you had no idea 6 months from now. Even if no one else posts, at least there will be some info for someone to go on when someone eventually comes across the same issues as you are having.
Cheers.
