Yes happens to me a lot too and not just on this forum.
If you take it totaly apart you can fit one in the back of a Ford Focus but you need to have epic Tetris skills for this.
The monitor is your only worry as that's pretty heavy if your on your own, If you are taking it apart then do so in the following order, as if you take the sides off before the monitor is out it can twist the frame due to the weight.
Back cover
Top cover
Control Panel
Front Bezel
Monitor out
Sides off
Monitor support off base
Then you should have the base with seat attached, can also take seat off to make it easier to carry.
