Sega space attack
Lurch666
21 (100%)
4,517CR
I'm in the middle of repairing a sega space attack and the halt LED keeps lighting up.
I've verified all the voltages,roms.address and data lines but the ram seems inactive.
All I'm getting is a blank white screen.
Now what I'm wondering is if the ram if faulty does the board have a quick memory test on startup that causes a HALT if it fails.
So does anyone have a working sega space attack?
What happens if you remove a ram chip-does it go straight into a HALT with the LED lit up?
Lurch666
21 (100%)
4,517CR
Beginning to think ALL eight of the ram (TMM4027) might be bad.
All
the inputs are active (data in,address,Cas,Ras and W) but the output is stuck low even if the output pin is removed from the socket so nothing
in those datalines could be affecting it.
I would assume even
if there is a problem with the circuit I would still get random data out
of the ram chips instead of just stuck low.
Unfortunately I don't have spares but looking at the pinout I'm thinking I could use
4116 ram instead since the only difference is the 4116 has an extra address
input on pin 13 where on the 4027 pin 13 is chip select.
But in this circuit pin 13 of the ram is tied to GND anyway so I'm thing the 4116 should be a drop in replacement?
Am I reading it right?
Lurch666
21 (100%)
4,517CR
Well I tried the 4116 and got a result.
All Ram is now showing output and I'm at least getting garbage on the screen and (sometimes) the HALT led is staying off meaning it's trying to run code.
Not sure if there's still some incompatibility with the ram but because known good 4116 ram is at least doing something I've ordered some replacement TMS4027 so at least it will definitely have the correct ram. It's just going to take a while since it's coming from China.
If it still doesn't work properly I'll at least know the ram is good and work from there.
GadgetFreak
963CR
My Carnival cocktail is a Sega converted Space Attack. It had ram issues when I got it and I too tried 4116 with bad results.
The reason is that the 4027's Latch the data and it remains valid into the next cycle whereas 4116's go tri-state after CAS goes high.
My board has several uPD414C NEC chips which are the same as TMM4027.GadgetFreak2022-02-24 14:15:11
Lurch666
21 (100%)
4,517CR
That's great news.
I was worried that if the 4116 ram was a direct replacement for the TMS4027 then even when I got the correct ram it wouldn't make a difference.
Now you have confirmed my suspicions that the cas and ras behaving different on the 4116 causes it to access incorrect locations plus the fact that at least the 4116 showing some output in this PCB confirmed that ALL the TMS4027 that were originally in the board were bad I'm now really hopeful that new TMS4027 ram will get the game running.
GadgetFreak
963CR
I too thought all my ram was bad but only ended up replacing one.
My board has two product numbers on it and a third Carnival one on a label. The 2 on the board are 814-0013 & 96384-P.
U56 (LS08) & U58 (LS151) both have been replaced and think these can cause memory issues.
Also I had to replace U20 (LS04), U22 & U23 (LS151), U24 & U25 (LS08), U7 (LS00) and U18 (LS157).
You may not have an issue with any of these but thought it may be worth listing them.GadgetFreak2022-02-25 14:06:25
Lurch666
21 (100%)
4,517CR
The reason I thought all the ram was bad is because none of them were producing any output. I should have at least seen random (initial state) data on the outputs of the ram chips but got nothing on any of them where with the 4116 I am seeing output (albeit incorrect because of the aforementioned differences).
We must also have different PCB's because on this one U56 to U62 is the ram and U20 to U27 are the eproms.
My PCB does match the schematics of the sega space attack manual I found online.
Lurch666
21 (100%)
4,517CR
WoooHooooo
So I'm still waiting for parts for various repairs to arrive including the ram for this PCB so I was poking around my space guerrilla PCB set that has upside down graphics when I noticed that the boardset also used 4027 ram.
It's not socketed but I've been dying to see if it was the ram stopping this space attack from working so decided to desolder eight of the ram chips to try in this PCB since it would be a good way of testing some of the ram in my space guerrilla by putting it into the space attack and I got the above result.
Now to try and connect the sound PCB and controls and see if they are working.
Lurch666
21 (100%)
4,517CR
Always feels good when A PCB comes back from the dead.
Just connected sound & controls. Everything fine except missing shot sound.
Just need to check the main PCB is sending the correct signal when the player fires and if it is then it's probably a bad cap or something on the sound PCB.
@Body pop.
You will need to check the voltages on your cab especially the -12V since this is what provides the -5V needed for the ram.
It could be a case of missing -12V that killed the ram since it can damage ram if that voltage is missing.
Body pop
24 (100%)
1,266CR
I’d say your on the money there lurch ,this is the voltages I got the last time I checked
And then I put a wanted add up for a working ar2
It seems to be an older rarer version of ar2 in this cab ,being that it was orbit
6.3 vac is 13
36 vac is 13.2
-15 vdc is 3.45
+ 10.3 is 10.3
5 v is 5.18
If any of that means anything to you ?
Lurch666
21 (100%)
4,517CR
If you can find the super space attack manual page 7 shows where to measure the voltages without the PCB connected and what those voltages should be.
Got the fire sound FX back.
It was just a poor connection on the makeshift connector I made to go between the main PCB and the sound PCB.
All good now.
Once the new ram chips arrive from China I'll get this sent back to you.
