Hi all
I am working on building a Sega racing Frankenstein Monster cab.
Its a Sega Touring car frame
Sega Indy 500 ROM
Sega Daytona Steering
Indy 500 motor drive boards
Touring car Audio Amps
So far things seem good, tho I have not checked audio, and I have not managed to wire up the Steering Feedback, due to the different systems.
The FFB PCB, outputs a 4 pin connection - 3 for the 110v Motor, one Earth (I think) - this would be used for the Indy 500 type Steering rack.
the Steering rack I have is a Daytona USA one. This uses a 110v reversible motor, and a Magnetic Particle Clutch.
Does anyone know the pinout of the Indy 500 Motor board - 838-11966. The Indy 500 Manual just says `Motor Out` for all 3 pins.
I need to know what these outputs do, so I can work out how to convert them to use a Motor and Clutch, rather than just the Motor.
Any suggestions - other than give up or replace the kit ?
As an alternative.... Would the Daytona USA board - 838-10646, work with the Indy 500 system ?
On Indy 500, there is a Motor control board (838-11967), and a Motor Power Board (838-11966).
It looks like the Daytona one (838-10646) may do the job of both ?
Can anyone help?
thanks
Simon
Sega Indy 500 ROM
Can anyone help?
thanks
Simon
