Sega System 16A PAL query
VectorGlow
34 (100%)
900CR
Does anyone have a System 16A boardset to hand please? I'm trying to find out the number printed on the label of the PAL at IC56 on the lower board. It starts with 315-
cmonkey
1,659CR
The MAME System 16A driver has this ASCII pic of the bottom board. Does this help you at all?
Bottom PCB
171-5307 (number under PCB, no numbers on top)
| 315-5144 |-|
| 2148 2148 2148 |
| ROM.IC24 ROM.IC11 |
| 2148 2148 2148 ROM.IC30 ROM.IC18 |
| D7751 |
| 6MHz |
| ROM.IC23 ROM.IC10 D8243C |
| 315-5049 ROM.IC29 ROM.IC17 |
| 315-5106 315-5108 |
| 315-5107 2018 2018 |
| 315-5049 |
| ROM.IC5 ROM.IC2 |
|TC5565 TC5565 315-5011 |
| 2016 315-5143 315-5012 ROM.IC4 ROM.IC1 |
|TC5565 TC5565 2016 |
Notes:
D7751 - NEC uPD7751C Microcontroller, running at 6.000MHz. This is a clone of an 8048 MCU
D8243C - NEC D8243C (DIP24)
2016 - Fujitsu MB8128 2K x8 SRAM (DIP24)
2018 - Sony CXD5813 2K x8 SRAM
TC5565 - Toshiba TC5565 8K x8 SRAM (DIP28)
2148 - Fujitsu MBM2148 1K x4 SRAM (DIP18)
315-5144 - Signetics CK2605 stamped '315-5144' (DIP20)
315-5143 - Signetics CK2605 stamped '315-5143' (DIP20)
315-5106 - PAL16R6 stamped '315-5106' (DIP20)
315-5107 - PAL16R6 stamped '315-5107' (DIP20)
315-5108 - PAL16R6 stamped '315-5108' (DIP20)
315-5011 - Custom Sega IC (DIP40)
315-5012 - Custom Sega IC (DIP48)
315-5049 - Custom Sega IC (SDIP64)
VectorGlow
34 (100%)
900CR
Thank you kindly, I hadn't thought to check the MAME driver.
It's 315-5143
