Sega Vector multi game project
Zektor
312CR
Finally my vector labs Sega multi game kit has arrived. Over the next few weeks I plan on converting a Sega star trek g80 pcb set into a multi game setup.
I'll post pics and Progress along the way. Zektor2014-04-22 20:58:07
Zektor
312CR
Ok I sorted the power supply wiring and booted up a spare Eliminator pcb set. I'm just starting to add the new parts ready for testing.
That's the CPU pcb ready to go.
Zektor2014-04-30 19:31:14
Zektor
312CR
After modifying the 3 sound boards I hooked the cage upto my vectorvga unit ....bingo !!!!
There is a problem with the sound though....,:-( time to pull the CPU board out.
Zektor
312CR
Another issue when using an Amplifone or WG vector monitor with a Sega vector game is the image is too small. The Sega outputs +/-4v and +/-3v where as the Atari colour vectors output +/-8v and +/-6v. Altering the values of a couple of resistors on the XY timing boards should sort this problem. I'll test it and document it.
Zektor
312CR
I found a bad ram on the universal sound board and the speech chip was also faulty (distorted speech)
Now I just have to figure out what's wrong with the battle star sound board.
Zektor2014-05-02 14:18:09
