Sera Rally - help please
Domain13
5CR
So after a 400 mile round trip to buy sega rally 2 I get home mega excited switch it on only to find that the screens are just displaying horizontal lines. I’ve no idea where to start with this one. Any suggestions please!!!
big10p
Coins detected in pocket!
6,092CR
Did you see it working when you picked it up? Check all cable connections are good - something might have come loose in transit. Can you hear the game playing? Post a pic showing what's displayed on screen.
big10p2020-07-14 20:22:40
2,272CR
Would be unusual for both monitors to get vertical collapse at the same time. Not impossible though.
Remote adjustment boards being unplugged will have the same effect as well though.
Can you hear the game playing in the background? Are the credit/view change buttons lighting up etc? Lots of things to check to narrow down the fault.
Domain13
5CR
thanks, annoyingly I didn’t see it working but even when I got home and called him he swares it was working And seemed genuine!?!?!
Photo attached and a shot of the digital display at the back of the machine if that means anything?
big10p
6,092CR
Did you check everything is plugged in snuggly? Particularly the game board connections. Monitor looks like its just displaying retrace lines, so is working, but not getting a video signal.
Domain13
5CR
are the game boards the ones under the seats? I guess they could have come loose during transport. I’ll double check they are all plugged in properly and fingers crossed!
Vamino
Insert coin(s)
2,700CR
Hopefully no damage has been done to the boards when transporting them. Model 3 games in Sega driving cabs really don't like being pushed over uneven surfaces, the vibrations can kill board stacks very quickly.
As well as what other people have suggested I'd unplug the output power cables from the power supply and check the voltages before doing anything, also check to see if the fans inside the stacks and PSU are spinning before even reconnecting the power again. I recently dug out a Model 3 PSU which was running at 5.8v. And when I adjusted the voltage it jumped from 4.8v to 5.8 v with no other adjustment in between! Some contact cleaner on the pots with the PSU unplugged sorted that out though.
Once these are serviced they can be very reliable. Left alone they can die a quick death.
Good luck!
Vamino2020-07-14 21:39:34
