Shinobi System 16
swisstoni
120CR
Ive got an original desucided Sega Shinobi System 16 board which works fine except there is a loss of colour (please see photos below). Ive switched the rom board to another working motherboard I have and it runs fine so the fault seems to be with the motherboard. The board looks in good shape the only thing is the gold plating has gone on some of the jamma edge (see photo) any idea where I could start looking to diagnose? Many Thanks.
swisstoni2022-03-30 19:34:58
TheDaddy
14 (93%)
7,230CR
Been a while since i did one but There is a couple of 6116 (think they 6116) rams at the back of the board under the rom board (Near the middle). Its normally one of them from memory.
Dave.
GadgetFreak
963CR
Have you gone into test mode ? (Pin22 Component side on edge connector)
After the first few screens it does ROM/RAM tests, not sure how much of the ram is checked but would be worth doing.
TheDaddy
14 (93%)
7,230CR
swisstoni said:
Thanks for the replies some things for me to look at. My first reaction was the issue would be with the connections on the jamma edge.
If that was the case the other A board would produce the same fault.
Dave.
qjuk
51 (98%)
2,120CR
Is your A board slightly bowed? I had a similar graphical issue on my Shinobi board set. In my case it was a poor connection bewteen the connector pins between the A and B boards. If I pushed down slightly on the B board the issue disappeared. I remedied it by adding another support pcb spacer underneath the A board which helped push it up into the B board to make a better contact. Never had a problem since
swisstoni
120CR
Cheers will give it a try.
RaveN
1,325CR
Dave.
Just to reinforce this, I fixed 4 of these, and they all had this issue.
sukhbir
46 (100%)
1,735CR
Possible there’s a problem with the colour srams,from memory there located on the bottom pcb .there should be 2 of them 2015 srams.if you have a scope try and look at the data I/O for bad signals which will help to find which sram is faulty.
