Silent Scope 1
jeff1979
1CR
Hello All,
I have a chance to purchase a silent scope 1 arcade machine. However the owner is saying that the machine has a fault code 46. I have tried looking everywhere on the net to see what fault this is, without success. Does anyone know what it is? Is it a simple fix or something complicated?
Thanks for your time.
Jeff
3,584CR
I don't know if it has a particular error code but it could be to do with the Timekeeper ram. As far as I know it's a fairly common failure on Silent Scope pcbs.
jeff1979
1CR
Thank you for the response. Is it complicated to fix? Can i read up on changing the timekeeper ram and change it? Or is that an issue you need experience on?
3,584CR
It's not something i've done myself but plenty of people have. As long as you're ok at soldering it shouldn't be too difficult. The hardest part would probably be desoldering the old ram without damaging the pcb.
tb20002017-12-27 15:49:52
3,584CR
gunblade said:
also you need to programme the new timekeeper with correct code
Yeah I forgot about this, I couldn't remember if it needed programming or if it was one that was programmed by the pcb itself, like with some boards when you hold down the test button when you switch them on.
jeff1979
1CR
Thanks guys!! Seems it would be something out of my scope! Just thought I could try, the machine would only cost $100 but might just be a waste for me.
3,584CR
Still a good price at $100 even if faulty i'd say. If you can find the details of someone whose arcade forums name is "channelmaniac" (I don't think he's on here though) I think he could repair it no problem. I'm fairly sure he's in the USA and has repaired literally hundreds if not thousands of pcbs.
Edit: channelmaniac is on here but hasn't logged in for nearly 2 years!
tb20002017-12-27 16:39:06
