Silver strike bowling
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Can anyone tell me if silver strike bowling has to be played on a medium res monitor or if it will work on a standard polo 1 monitor?
Thanks,
Steve
jengineer
49 (100%)
1,205CR
Silver Strike machines have a Polo Star or Polo 2 monitor
and seeing as its PC based I don't think it will work with a polo1
jengineer2015-02-08 09:43:22
bonehead
50 (100%)
1,729CR
I have a polo star try sinc 28" chassis here. Could I fit that into a tube that has a polo 2 chasis?
I know the tube is a 25" in the game but it has a 28" chassis fitted. The op told me the monitor was faulty when I bought it a year ago.
Cheers.
jengineer
49 (100%)
1,205CR
you'll need someone with more experience to tell you, if its not compatible you'll blow either the chassis, yoke or both
jengineer2015-02-08 10:15:49
tb2000
3,578CR
You can't use a Polostar chassis on a Polo 1 or Polo 2 tube as the yoke spec is quite different. Polo 2 25 and 28 chassis are compatible so can be used on either size tube, same goes for Polo 1. I think you can use Silver Strike on a standard res, they use a pcb of some sort to convert the vga output anyway.
