Silverline cab electrics
Ste72
152CR
Hi
I've just got back into cabs and obtained a Silverline with a 19" WG 7689 monitor which says 120v / 85w on it. I don't know if it actually works as the wiring didn't look too promising so haven't tested it. I've posted some pics below for views on what I need to do, but warnings started when the mains plug was on a cable that had the copper cores clearly visible as the rubber covering had been scraped back. I've cut this off to start again (thats about as far as my knowledge goes!) but thought other things might be worth a check first. I do know CRTs and electrics like this are not to be messed with.
This is the isolation transformer I believe? Two of the wires come from this to the monitor (cream and black).
Isolation_Trans&
This is what the monitor power is connected like. Seems a bit flaky to me with those blocks. This comes from the transformer above.
Anything need to be done here before I apply power? Even if just tape-up the connectors with electrical table? I don't have any electrics know-how whatsoever btw!
Thanks in advance.
Ste
Ste72
152CR
Thanks I can do that. If all is well, does the wiring on the pics look a bit 'thin' and flimsy? Should I replace with something more robust?
