Slimmed down MVS4 active marquee
Doctonic
9CR
Currently in the planning process of building a slimmed down MVS4 with an active marquee.
There is a full thread over on BYOAC, but I'll cover it over here too JFSAG.
Putting this here now although may be a few weeks before any wood gets
cut. (Got a few things to finish off in garden first). I Will be looking
for Opinionions/recommendations on this one.
I've had a Bartop
for a few years now, but it just doesn't get the love it should do.
Because of this I am going to sell the bartop and start again with a
full size unit. For this build I have decided to go with Jakobuds MVS4
plans but I will be adding another row of buttons giving the standard
streetfighter layout with extra button. I also plan to take about 10"
off the back of the unit, I will keep the general shape so the only
difference will be the height of the vertical piece at back.
The
plan is building from ply or similar and then laminating. (Any
recommendations for close match to Neo Geo Red available in the UK?)
To
make an active marquee I am going to use a 25" Widescreen and for the
main screen area I wanted to be able to play both horizontal and
vertical games as close to original sizing as possible, to do this I am
planning on using a 43" 4k screen mounted vertically (Approx 1/2 screen
should be visible), This will then require custom resolutions and
layouts creating which may take some time. (Any recommendations on what
Video card/software is capable of doing this kind of thing easily)
As
for art, I think I will just go with the standard NeoGeo MVS transfers
resized a bit due to the machine being on the adkins diet, and also use
the standard control panel art with relevant modifications for credit
buttons and the like.
Ideally I would like to install a coindoor for the aesthetics (Anyone got any good links for UK suppliers?).
I'm hoping to get a viewable area about 2000x2160 (So can still have
full HD displayed in the visible area) If I use a standard full HD I
would be looking at about 1000 x 1080, Which is fine for most emulators
and stuff but not so good for music videos (Although to be honest I
could always display those on the Marquee monitor
See attached modified Jakobud plans, may be a tiny bit off but should be good enough.
Green is 24" Monitor from work, without stand is 13" High, Black underneath will be speaker location
Red
is 43" Screen (Will purchase) Looking at the sight lines I should have
approx 22x22" visable screen area (Maybe a touch more).
Doctonic
9CR
OK I have been looking into Laminating options, I don't have a legit
Neo-geo so can't compare, but looking around the Fire red seems to be a
fairly good match. I have found a company in the UK that can supply
Blaze red as follows. If anyone thinks one of the other options would
be better let me know.
Red = https://www.morland-uk.com/shop/shop-fit-out/laminate-sheets/formica-hpl-laminate-sheet-f2824-blazered.html?___SID=U
And now for one of those Opinionion moments, Should I use Textured or untextured for the black?
Textured Black = https://www.morland-uk.com/shop/shop-fit-out/laminate-sheets/morland-hpl-laminate-sheet-black104.html?___SID=U
Matt Black = https://www.morland-uk.com/shop/shop-fit-out/laminate-sheets/formica-hpl-laminate-sheet-f2253-diamondblack.html
Alternatively
should I use osb/mdf bonded board and then paint. Personally I like
the Idea of Laminating but get the feeling if I cock it up then it will
get pretty expensive pretty fast
For
speakers I have a spare set of Logitech X530's I figure I should be
able to fit them underneath the monitor firing out front, I will then
have the centre speaker behind the monitor firing down and the 2 rear
speakers can be located left and right of the centre pedestal area.
I'll have to remove the circuit board from the front speaker and wire
that in elsewhere so I can still have access to headphone options and
volume control. I do have a spare logitech zx5400 set but A) the
speakers are too large to fit in the available space, and B) I don't
need 310W of power in an arcade machine, not even if that machine was
Guitar hero or Dance Dance
Coindoor, looking into coindoors and can't really find anything readily available in the UK, I have though found the following
https://www.ebay.co.uk/itm/Universal-Arcade-Machine-Cabinet-Door-2-Coin-Slot-Comparison-Mech-MAME-JAMMA/362343865733?hash=item545d609d85:g:QKgAAOSwNNVbF6Eh
I can then hang one of these underneath
https://www.ebay.co.uk/itm/Arcade-Game-Metal-Coin-Door-Access-For-Coin-Acceptor-Doll-Machines-Accessories/202336748172?hash=item2f1c35c28c:g:MEQAAOSwfp9bGrnj
Alternatively
I could get a panel made up and use 2 of these but it would cost more
and require a custom panel to be made so definitely leaning towards
click and forget
https://www.ebay.co.uk/itm/Front-Plate-Assembly-With-Cradle-For-3-5-Arcade-Coin-Mechanisms/371961635110?hash=item569aa42126:g:DWgAAOSwjjpa9EYw
(Ive posted in the WTB section)
Yep the more I look at it the more I think Matte all round will be the best choice.
I
figure that building this machine would be possible using a straight
edge and a skill saw, both of which I already have, But I can see a few
places where I am going to need to make some interesting cuts on angles
so I have decided that I may as well add to the tool kit and have
purchased the following.
https://www.amazon.co.uk/gp/product/B01LYDELEC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Having
looked at reviews for pretty much every table saw under 200 and coming
to the conclusion that they were all going to be a little bit rubbish I
moved up to the under 300 and the above came out a clear winner for the
hobbiest. I feel that it is a fair investment as I do have to make
some storage for an upstairs bedroom which will have all sorts of weird
angles involved.
I already have 2 Routers, a jigsaw, 2
skillsaws, a 210mm Sliding Mitre saw, more drills and bits then I can
shake a stick at, a portable Drill press and I even have some 900mm
clamps so I think that's all the tools I will need. (Actually scratch
that, I really need to get/make a router table). I have access to an A0
plotter at work so should be able to print out the sides to full size.
Controls,
I
want the controls to be mostly authentic to the style of the machine,
Looks like either competitions, ultimates or IL Eurostyle, I am
currently favouring the IL
https://www.arcadeworlduk.com/products/il-eurostyle-joystick-with-cherry-microswitches.html
Buttons
will be standard colour layout with BCD on both top and bottom rows, I
will have an additional button on control panel for exit thus having 4
instead of standard 3.
https://www.arcadeworlduk.com/products/white-il-concave-arcade-start-button.html
https://www.arcadeworlduk.com/products/il-psl-h-concave-arcade-button.html
Doctonic
9CR
I decided to mock everything up in sketchup, haven't used it in over 5 years so basically had to learn it all over again. Managed to get a 4K 43 inch which has a broken digital tuner (But works fine on HDMI) for £100 should fit with about 2mm each side :)
Ordered wood which when turned up for delivery was damaged on 2 edges, no good what so ever. I'm waiting for it to be sorted and new ply delivered.
In the meantime I'm still going back and forth on the buttons/joysticks to use, in the meantime I am going to fit 4 way leaf sticks and buttons into my bartop and use the magstick plus and buttons from that for testing.
