Smd desoldering
bones
1,628CR
I'm probably going to be repairing a Sega eighteen wheeler cart by block replacing all the smd buffer chips. I've never actually worked with these before so in preparation I acquired some low melt alloy solder,some flux and some alcohol wipes I'm still awaiting some braid to remove the excess solder and clean the pads.
Now the low melt solder is an expensive 75°c one and straight away I realised my cheap rework station starts at 200°c so I suppose I could have bought the 135°c alloy solder at a much cheaper price doh!
Secondly I bought the flux in 2g tubes where you have to cut the nozzle to allow it to come out. It works but the application with these tubes is not as precise as using the syringe ones. I feel I probably used much more than necessary but it's not that expensive.
I didn't have any old computer rams to practice on,but remembered that I had an old football champ I'd got in a job lot of PCBs. It had never really worked and I realised that a large square chip had a lot of bent pins and hard flux in those areas, so I thought this could be my victim. I believe if you pressed down on this chip the game booted and look pretty ok.
I fluxed all the legs and started to add the alloy, initially I tried to use as little as possible but realised that you need all the legs on each side to be coated as one to allow you to run your iron round and round the chip to get all the soldered legs to a high enough temperature for it's removal. I guess on a 2 sided diddy buffer chip that's going in the bin it will be far easier to remove.
Anyway after about 5 mins of applying more alloy and running the iron around each side the chip lifted and without the braid I cleaned the PCB up as best I could. Now the chip itself has some bent pins on it where I tried to lift it to early and all the legs are link together by the alloy solder mix but I'm sure once I've got the braid I can correct this.
So this is the current state of the PCB where this chip goes at present before I clear the old solder with the braid and re-tin the traces.
bbz149
26 (100%)
1,608CR
Nice job!!
Yeah that Chipquick is freaking expensive! You going to use Solder paste and hot air to re install, or Flux and drag?
Would this stuff be any good for me to remove a 28 pin HSOP? LINK
bones
1,628CR
bbz149 said:
Nice job!!
I reckon that will be fine for the job, I looked at that first to be honest but thought I'd start with the top quality and work down to get an idea of the differences if any.
As for resoldering that chip I hadn't decided yet, the solder drag method looks cool but I'm wondering if the pitch between the legs might turn it into a nightmare so the solder paste may well be the best option for these style chips. God bless you tube though, I'd have never dared to have a go otherwise.
redleader
50CR
Don't re-tin, you need the ic to be perfectly flat.
Clean of all solder/chip quik with braid be careful of direction as not to lift any pads then
clean pads with isopropyl alcohol allow to dry, apply flux with syringe don't be afraid to use
good amount, rest ic in place push down slightly so it sits perfect, check with magnification
all pins are lined up, tack the 4 corners , drag solder across all pins, practice on old boards
if you need to, any bridges just apply some flux and drag out, try to use a good quality flux,
i personally use Kingbo flux,
good luck !
bbz149
26 (100%)
1,608CR
bones said:
bbz149 said:
Nice job!!
Yeah they make it look so easy on Youtube
Cool ill order some of that then
I got plenty of Flux
I got the Chip Quick Flux free from work, not cheap! Also bought the Mechanic UV non clean from China which is quiet good! Be sure to post pic's when completed
bones
1,628CR
Thanks redleader, the flux I've got is chipquik too, if I use the drag method is it best to use the flat angled solder tip like I saw on you tube or does it not really matter ?
bones
1,628CR
bbz149 said:
bones said:
bbz149 said:
Nice job!!
I will post the results and hopefully I won't end up with a big blob of solder where the chip was lol. I was thinking that perhaps at the start of this maybe I should have used the air gun to help bring things up to temperature quicker. I wouldn't be able to do that on the Sega cart though as there's a few descreet smds in the vicinity
Monstermug
1,807CR
Use Amtech NC-559-V2-TF Tacky Flux. It's a million times better than Chipquick flux. Trick with smd is to flood with flux. I only use the low melting point solder for customs to avoid excessive heat damage when removing. Stuff that doesnt require it gets hotaired off with my weller hot air station.
When soldering back on use loads of flux and a clean iron tip. Drag solder across the legs to give it that factory look. Took me a few years to perfect the technique. Low melting point solder is a bitch to buy. £120 quid for that tube.
Forgot to mention, use lots of isopropyl and kimwipes to remove flux afterwards. I use my hot air station on low settings to gently blow away excessive flux trapped in between the pins to make cleaning easier. A microscope is a must if you don't have perfect vision and even then should be considered. Changed some konami QFP customs on a Simpsons board and asked a few mates if they could guess which customs I replaced. Not one got it right
Monstermug2020-09-14 11:15:27
bbz149
26 (100%)
1,608CR
You wana sell me a strip of that chip quix
Monstermug
1,807CR
You need more than one to remove a QFP buddy. About 1 1/2 stick which works out to be about £10
. Yeah cost me a £10 to remove any custom QFP
Also I find rather than going around the ic with a soldering iron and risking bending the legs, I mix the quickchip into the existing solder and then use my hot air station to remove the chip. Comes off in a few seconds as apposed to several minutes, drastically reducing damage to the chip.
Monstermug2020-09-14 11:19:46
bones
1,628CR
oops me thinks I'm a bit of a skinflint here,only used about 2 inches, so about 1/2 inch a side lol. Good advice though,heeded for certain.
bones
1,628CR
bbz149 said:
Monstermug said:
Use Amtech NC-559-V2-TF Tacky Flux.  It's a million times better than Chipquick flux.  Trick with smd is to flood with flux.  I only use the low melting point solder for customs to avoid excessive heat damage when removing.  Stuff that doesnt require it gets hotaired off with my weller hot air station. ?
Got mine from Amazon, 9 strips for £31.49 (6 inch lengths) ouch.
