SNES Help wanted
dlightbulb
64CR
Hi guys,
Having problems with my US SNES
Controller port one is pressing b and y when you just press b.
It is definitely not the controller as I have tried it in other SNES'
On opening the console I can't see anything out of the ordinary
Any ideas are much appreciated.
Dave
GameOn
133CR
The SNES joypad uses a serial data stream so it is the CPU that decodes it, so it is unlikely to be the SNES at fault. it could be that the pad has accumulated enough sweat from fingers, that it is making a high resistance connection, which one machine is noticing and the other is not.
I would open the pad up, which should show if there is anything in the pad that might be causing it. Once opened, just clean the board and rubber pad with a cotton bud and some weak isopropyl alcohol (about 50%), you will probably remove a lot of gunk.
Also check the pad to see if the circular pad has broken off or is hanging down, it could also be that the pad is touching the board slightly and pressing B is pushing it enough on the board to cause enough of a connection to make Y show as a press. If this is the case then rotate 180 degrees while you hunt down new rubber pads.
GameOn2016-11-10 13:13:20
dlightbulb
64CR
Hi mate, thanks for the info - but the problem is I have used 3 different pads in the SNES and they all have the same problem. They do not have this problem on my other SNES..... Therefore it surely can't be the pads
vib_ribbon
488CR
do you have the means to open one up? i seem to recall that you can unplug the joypad sockets via a ribbon cable. can you unplug it and maybe switch it over with one from another snes to eliminate the problem?
