Solve static through cab speakers?
thesharkfactor
31CR
Long time ago, I upgraded my cab's mono speaker with 2 new speakers and I plumbed in a little amp with a volume control on it which sits outside the cab on the for easy volume access.
Trouble is, i'm getting static through the speakers (as well as game sounds), it's bothering me more and more and I'd like to solve it.. would this be a simple grounding issue?
It was a while ago, I'm considering undoing the job and re-doing it to see if I can uncover a mistake or whatever.. any advice?
big10p
Coins detected in pocket!
6,093CR
Are you playing actually PCBs or some MAME setup? Most game boards have sound amps on them, so you're basically using 2 amps, which isn't the best idea. However, I have this kind of setup on a couple of JAMMA cabs which is fine as they are both running MAME setups, but on the rare occasion I do plug a JAMMA board in, I simply turn the board volume down to minimum, and use the cab amp to set the actual play volume.
thesharkfactor
31CR
Thanks for your help.
I'm running a pandora. Just looking over the wiring now, I have forgotten much since I wired it (I installed a new chamma loom myself). I have a 3.5mm jack from the pandora board plugged in to the external amp. There are speaker wires coming from the amp and connected to the cabs 2 speakers. Straight forward. The power for the amp is taken from the cabs psu.
I note, that if I pull the power plug from the amp, there is no static (and no sound either).
Maybe I will try run a ground wire from the cabs psu to the metal frame of each speakers?
EDIT: just noticed the cabs psu is 12v/2.5amp, the sound amplifier says it's 12v/2amp. Would this be the problem, too many amps?
thesharkfactor2019-12-28 14:23:07
TheDaddy
14 (93%)
7,230CR
I had one in a mame set up and it shocking so i switched back to a hacked set if pc speakers. No issues with that. Its prety much down to cheap china products, well it was with mine. I was going to see if i could fix the issues with ferris shields and what not but never got round to it.
Dave.
P.s as also said with 99% of jamma these should not be needed.
P.s.s amps should be fine , it will only draw what it needs.TheDaddy2019-12-28 14:25:48
thesharkfactor
31CR
OK.. good to hear that. I'll remove it and go back to the mono speaker jamma set up until i get a better amp.
FYI, I found it useful when using mame/pandora as every game plays at a different volume ( im sure you know this) and the external volume control is really necessary otherwise i need to open the cab and climb in every other game i load.. lol
big10p
6,093CR
Are you connecting the amp to the PB using the earphone jack, or the JAMMA edge connector? I have a PB6 which outputs stereo via the headphone jack, which I have connected to a stereo amp. Sound is fine as the output is not amplified through the headphone socket (I think), but it is through the JAMMA edge (which is only mono, obviously).
big10p2019-12-28 15:14:23
thesharkfactor
31CR
Fixed! Took me a few hours tinkering I hacked in a pc amp, powered off the cabs psu, hooked up to the cabs speakers. Zero static, all working! Awesome, thanks for everyones advice.
volume and bass knobs
hack left overs for the bin..
crap..
thesharkfactor
31CR
Having a big bass box in the cab is not sitting well with me, so i'd like to finish the job off with a tidier and long term solution.
Can anyone recommend a particular small pcb stereo amp with a volume knob that produces good results and doesn't hiss?
I'm talking about something like this..
..for example, that is £4, but is mono and it might be a waste of time..
5,415CR
I'd sooner buy some quality older amps like the Electrocoin ones or use Sega Amps
You could always add one of the isolators to stop buzzing
Had issue with noises coming through mp3 player and Electrocoin Amps other week, was powering all with one standard PC monitor type 12v adaptor, soon as the mp3 player on separate one all noise went
The other day I was thinking about the Star Wars cab, still need to sort that issue out but i'll start my own post
thesharkfactor
31CR
Thanks guys..
big10p said:
Yes, this is perfecto! Thanks mate, exactly what I was looking for. I bought one. I can plumb that in somewhere nice and convenient.
I'll update once the job is done.
