Sorted - Isolation transformer issue
RolyRetro
278CR
I’m in the process of restoring an Electrocoin Midi, starting with the Kortek monitor which has had it’s chassis overhauled (thanks to gunblade)
I’ve reconnected all of the power and video plugs, and am getting solid 5v, 12v and -5v measurements from the transformer. The marquee lights up, and the known working game can be heard through the speakers. I get the thump of the degauss circuit but no display on the screen and no neck glow.
I checked the power going into the monitor and didn’t seem to be getting anything at the plug, so traced it back to the isolation transformer, and It doesn’t seem to be producing any output voltage, I can only read the 240V going in.
I believe I should be getting 120V ac out, but there is none. I’ve heard that these things don’t tend to break down as well...anyone have any ideas? Should I be be thinking about replacing the isolation transformer or am I missing something?
RolyRetro2017-10-26 15:24:11
jengineer
49 (100%)
1,206CR
what sort of transformer is it? is it on its own? or is it part of an electrocoin power supply with the fuses and switcher fitted inside etc
any decent clear pictures?
jengineer2017-10-24 23:09:01
RolyRetro
278CR
It’s the latter, the lift out metal panel with power supply and isolation transformer attached, and fuses and molex connectors integrated into the top of it.
I’ll take some pics tomorrow if this will help?
gunblade
9,144CR
so 2 of the wires are 240vac from the primary side of the iso and the other 2 wires are 120vac from the secondary side
unplug the monitor power connector and check the 120vac output again
transformers do fail, normally due to corrosion or physical damage
RolyRetro
278CR
I just get the 240v from one side, nothing from the other. Does this suggest the transformer is knackered?
gunblade
9,144CR
you said you had fuses on the iso-probably one them is blown
RolyRetro
278CR
I checked the fuses, they all have continuity...I checked the outputs from the bottom of the transformer labelled 120-128 and nothing coming out at all :(
RolyRetro2017-10-25 10:31:43
RolyRetro
278CR
I’m using the black probe on the chassis, but someone has just mentioned something about floating voltage - how do I test this? Where does the black probe go?
DanP
Administrator
2,232CR
This is AC voltage so putting your black probe to ground won't work, at best you'll see half the voltage. Probably easier to measure at the connector where it goes into the monitor plug, there should be two wires put one meter probe on one wire the other on the other. If your meter is set to AC you should see values. If you have nothing, trace those wires back and measure at each point(s) to see if it appears anywhere along the chain to the iso transformer.
RolyRetro
278CR
I finally have a reading, it’s showing 133v from the connector to the monitor, so the power seems to be ok, unless this is a bit high? I still have no activity from the monitor, no neck glow :(
As I've address the original symptom I'll close this off while I explore other possible causes for the lack of display.
Thanks for your input, especially gunblade :)
RolyRetro2017-10-26 15:23:44
