Sound circuit caps?
paulcan69
945CR
I want to buy a load of common sound circuit caps.
Can anyone tell me the common values, or is there somewhere where you can buy kits, like what Maplin do, but I'm concerned if I buy a kit from Maplin I'll have 3 caps used in arcade pcb's and 197 which are the wrong values and are for remote control cars or something.
I guess my question is:- Is there a better way of stocking up on sound circuit caps for arcade pcb's other than checking each board and writing values down?
Thanks for any advice.
Ta.
paulcan692011-04-01 12:11:08
trm
2,877CR
The best way to determine this is to gather a load of PCBs together and go through noting down which caps appear and what frequency
. Or wait till you're fixing a board and you know the sound caps are suspicious. I'm not a fan of shotgunning as you may notice
If you don't fancy that I'd suggest something like one of the Maplin/Velleman capacitor packs. They do a few of these including electrolytic and ceramics. They're sub £10, have a range of capacitances and include multiples of the same part so you get a reasonable stash.
Having a quick non-scientific look you want electrolytics in the range of 1uF up to about 1000uF and occasionally something around 2200uF. Bear in mind though that you're going to see more than just electrolytic caps in sound stages - there will be tantalum types too (for some purposes you can swap for electrolytics, but the caps in a sound stage are often used to make bandpass filters so the characteristics of the different technologies might affect the sound).
Basically there's no quick and simple answer to this. Also I've very rarely had to replace caps to get sound working again - maybe a handful of boards where the sound was working but was missing big frequency bands. Most of the time it's something like the op-amps losing a channel or more, or the synth chips not functioning.
I'd probably grab one of the Velleman electrolytic packs from Maplin and then buy as needed based on what you're fixing.
