Sound issue - Revolution X
ltearle
57CR
Today I picked up my Revolution X - Aerosmith arcade machine and there is no sound! I haven't investigated to much but I believe I have the same problem as someone on (KLOV). This is what he put:
When i opened up the back and took a look, the light on the gun board was lit, the light on the sound board wasn't, and of the two lights on the main board one was lit and one was blinking.
Does anyone know how to fix it? Or could help me!
Luke
trm
2,877CR
Hi Luke,
I'm going to move this post into Tech shortly as you'll get more technical eyes on it there to hopefully help you get this (terrible, IMHO
) game working.
As for a few initial questions to help with the investigation:
Does the rest of the game work as expected?
Have you (or the previous owner) had the sound working?
If somebody who's seen the insides of this cab doesn't come along with the answer shortly, could you get some good photos of the board set, interconnect cables and anything else you think relevant from the back of the cab?
tim
ltearle
57CR
Thanks Tim. I will add pictures as soon as I can.
The sound hadn't worked for the previous owner. Everything else seems to work. The guns need recalibrating but I know how to do that (read it on KLOV).
Will get this all sorted soon :)
ltearle
57CR
Hey Guys!
Got a two pictures and a video of the boards for you. The only which I would point out is that one of the LEDs keeps flickering when sound is supposed to be played. When it is turned on it makes a noise which would indicate that the speakers are on. Please help me fix it!
If you need anymore pictures to try and help please ask.
lukeearle2011-10-25 13:51:07
ltearle
57CR
This is the thread I found on Klov. Doesn't really give any solutions though:
http://forums.arcade-museum.com/showthread.php?t=173939
ltearle
57CR
shep said:
Â?
What results do you get from the sound tests described in the manual here:
Â?
http://www.crazykong.com/manuals/RevolutionX.man.pdf
Â?
Also, check the volume settings which are set from the menu system and take a look at the sound troubleshooting section.
Â?
Gary.
Thanks forgetting back to me Gary. I haven't checked the sound board as I took the pictures quickly and didn't notice it (am I not even sure it's there). I will also do a sound test to see whats what. I will add the picture when I get chance this week :)
lukeearle2011-10-27 07:31:24
ltearle
57CR
Got a marquee from America today. There is a crack in it though so not impressed. Will get pictures of the sound board soon :)
