Sound Pot error?
Woodstock
6CR
Hi guys & gals,
I have got a double dragon 2 pcb that appears to have a sound pot problem. When I turn the pot screw with a small screw driver, it crackles a lot and either the sound becomes too low or way too high, it is impossible for me to set it to a level that I find acceptable. Does this sound like a "sound pot" problem to you? If so, can anyone recommend somewhere where I can buy a new one so that I can replace it? Thanks for any help!
Woodstock
6CR
Thanks bbz149, so you think if I get some of that switch cleaner it might be worth giving it a spray and sometimes that helps to resolve the problem without replacing the pot?
big10p
Coins detected in pocket!
6,085CR
It isn't a guaranteed fix but worth a try before replacing the pot. Give the pot a good few full turns when you've sprayed some into it.
bbz149
26 (100%)
1,608CR
As long as the Carbon is not worn on the track then it should do the job. As Big10p said give it a good few turns in both directions after spraying
Woodstock
6CR
Hi,
Sorry it has taken me a while to get back with an update. I tried the electrical cleaner spray today and it certainly made things a lot better. I had to pry a small plastic cover off of the pot before spraying it, as it effectively protected the pot from getting any spray into its workings.
The sound still isn't perfect, the sound still crackles and becomes very loud when turned to anything but the minimum setting on the pot. However, I have found that when turned to the minimum setting, the volume is about right and pretty clear, so happy days :) thanks again for the advice!
