Space harrier controls
Bobbdobalina
146CR
Hi all, I’ve got a space harrier that I’m trying to get up and running. I found that the left /right pot on the controls was seized so eased it with some contact cleaner, which worked great.
I then tested it and while it was reading high, 29k ohms and the pot is 25k ohms it ran through its range smoothly with no jumps etc.
However I’ve now got my board set back after repair and left/right doesn’t work.
Put it into the output test and up/down reads fine but left /right just says FFH .
I’m assuming it means not working but I can’t find FFH in the manual and wondered if it denotes any more information.
Any help with this is much appreciated.
Fantazia2
2,246CR
Dont Sega normally use 5K pots for analogue controls?
Is FFH not a hex value based on the input, assuming up down shows a range of numbers.
Just checked and FFH is binary for 255 so that would match up with an input range of 0 to 255 or 8 bits from an Ananlogue to Digital converter.
Bobbdobalina
146CR
yeah sega do normally use 5 pots, but the 25k were already in there and I assume have worked for some time during it’s life. And the up/down is 25k and works fine.
So the FFH is basically just telling me a value and the the pot is over range. Makes sense, I’d assumed as much but was just curious.
Thanks for the reply, I appreciate it.
