Space Harrier - lines going down screen
ian_us
30CR
Earlier today I took my Space Harrier board out of its cabinet and took it to a local professional to get some new IC's. Everything tested great on his set up, and I've got no more bad ram when running diagnostic mode - so that's good!
Unfortunately, when I plugged it back in, I run across these vertical lines going down the screen. I think it's related to the monitor cable, as one of the wires slid out, and I had to slide it back in (with results shown), but I want to make sure I'm not running in circles here...has anyone else had this issue before? Could it be a different connection?And is there an easy source to buy a replacement monitor cable?
See attached
dj_yt
787CR
Thats a PCB issue I suspect. It *could* be an issue addressing the sprite ROMs.
Have you reseated all interconnects and checked voltages as a first step?
ian_us
30CR
I have reseated all interconnects, have not checked voltages as my multimeter took a crap and I'm waiting on a new one.
This PCB played perfectly on the repair tech's setup, so I'd like to think it's an issue with my setup and not the pcb, but you never know!
dj_yt
787CR
Yep, I'd check voltages on all PCBs if you can as a next step. Test some chips on the far side of the PCB by placing the multimeter on a ground and +5v pin of an ic. You can find the pinouts by googling if unsure which pins to test. I have had serviced SH PCBs go wrong almost instantly so it's not impossible there's a new problem either. But fingers crossed it's a simple one.
ian_us
30CR
Will do - thanks for the heads up, I'll have to sit tight for a few days before I can do that. Hopefully this problem magically fixes itself in the mean time :O
Hurray Banana
2,766CR
It definitely looks like that or a potential rom failure
ian_us
30CR
I've managed to get rid of the vertical lines by swapping a few interconnectors! Phew. But now I have a color problem that didn't exist ten minutes ago..super. This i really do imagine goes back to my crappy video cable. I was so close!
ian_us
30CR
Color problem fixed too. I made some more switcharoos due to the age and filth on some of the wires/ribbons on the boards.Thankfully I had a spare Enduro racer harness lying around.
Thanks for the help guys..fortunately false alarm, not a PCB issue, just a me-being-stupid issue or bad cables.
Game looks great!
