Space harrier Seized pot
Bobbdobalina
146CR
Hi all, the left - right pot on my space harrier has seized. It will move with some persuasion ( grips) but not usable. The controls had some gears missing when I bought it which I’ve now sourced and the pcb was faulty and will hopefully be coming back soon. So I’m determined to get this baby up and running.
Is this done for? Or can I ease it? And if so what would be the best product to release it?
Thanks in advance for any info you can give me.
5,415CR
Well my Thunderblade deluxe pot the seat moves when it turns was bending the metal bracket as you turned seat, the pot was that tight, i took it out and removed rear cover off pot but couldn't remove centre wiper, so just carried on spraying it inside and down shaft from outside and turned till it worked loose
Normally pots have damper grease in them so they dont turn freely but these ones need to be free and turn with no resistance, when people spray them in old stereo gear with switch cleaner to stop them crackling they can wash the grease out, but these its opposite case so spray away or leave it soaking in some cleaner
If there original matsush*ta ones with traingle logo they are top quality and tracks inside this were fine still so worth saving
Servisol switch cleaner which is handy to have anyway Bods2021-08-22 20:24:29
Bobbdobalina
146CR
Thanks for the reply. Will WD40 contact cleaner work just as well?
It just that I can nip go B&Q to pick it up
Bobbdobalina
146CR
Got some WD40 specialised contact cleaner from Halfords and it worked a treat. Took literally seconds to go from solid and unable to move without grips to free and easy rolling between fingers.
Gave the other one a squirt for good measure.
Thanks for the help everyone, another job ticked off the list
Bobbdobalina2021-08-25 19:22:45
