iamjimmi said:Question for JB (sorry going off topic) - I've just noticed that the switcher isn't grounded. As well as providing 5V for the games boards, the switcher also provides 5V for the Motor PCB. Could this have anything to do with my motor issues?
I'm bit confused by the earth wire to be honest, it has them going from the mains cable in which earths the metal base, has post on outside assume for countries that don't have earth on mains plug
From that one earth goes to big transformer metal bracket and another from there to the smaller transformer metal bracket, can't work out why though Jim, because the big one has paint on it, so doing nothing and when I undone bolt on smaller one, it has plastic insulating washer so the bolts through transformer don't link each side, big one has plastic washer to by looks of it
It did cross my mind if it maybe something daft like earth or filter causing motor issue but mine has no earth to 5v PSU, i've added one which has cut out lots of buzzing but not all.
When you can Jim, could you check where you input power goes from on you rear lamp pcb, mine goes to big transformer?
Think it says 9.5v 2.5 amp, the other wires I think went to Motor Drive PCB through the fuse
