Space Harrier Testing
5,415CR
iamjimmi said:
Question for JB (sorry going off topic) - I've just noticed that the switcher isn't grounded. As well as providing 5V for the games boards, the switcher also provides 5V for the Motor PCB. Could this have anything to do with my motor issues?
I'm bit confused by the earth wire to be honest, it has them going from the mains cable in which earths the metal base, has post on outside assume for countries that don't have earth on mains plug
From that one earth goes to big transformer metal bracket and another from there to the smaller transformer metal bracket, can't work out why though Jim, because the big one has paint on it, so doing nothing and when I undone bolt on smaller one, it has plastic insulating washer so the bolts through transformer don't link each side, big one has plastic washer to by looks of it
It did cross my mind if it maybe something daft like earth or filter causing motor issue but mine has no earth to 5v PSU, i've added one which has cut out lots of buzzing but not all.
When you can Jim, could you check where you input power goes from on you rear lamp pcb, mine goes to big transformer?
Think it says 9.5v 2.5 amp, the other wires I think went to Motor Drive PCB through the fuse
5,415CR
Ignore the power from Transformer, it does say 9.5V 2.5A
Can't read the Diagram as it's so poor, think that should say 9.5v but looks like 2 5 v and it does go to Drive PCB also through fuse so thats fine
Must be something fails under load then I guess as voltage ok with no bulb
5,415CR
Lamp PCB, Had a look and found in Draw of old components a perfect replacement bridge so try that like you said John
Job Done
Bods2021-08-10 12:10:45
smarty
Ready Player One
1,305CR
Nice work Bods. Great to see you with some arcade mojo! From what I remember and see, you have a great selection of cabs.
Shame Sega didn’t make the lamp flash rate change when you were fighting a level boss or something like that, my testing in MAME seems to have it constantly flashing at the same rate in attract and during gameplay.
5,415CR
Hi Smarty
Yes, it doesn't seem to change at all as you say, which makes you wonder why it's linked to game board as it could of just been Timed circuit flashing same, They could of done it when you fire or get hit. Nice to see them work though
It's nice to spend some time on the machines, so much has gone on Cars which drives you mad battling rust which is why in first place I decided on Arcade machines rather than cars but i get a bug for things and with those if you don't buy at the right time then you miss chance unless your loaded.
These old Arcade machines are easier in that way and no hassle with Tax etc and cheaper to run
but still have their Challenges, like this yesterday when I lost the title screen and half the gfx, you just think oh god, the board has gone bad, only moved the main board a little as it was near edge of wood, then I moved cable to Audio pcb and its back ok
Just wish I hadn't got quite so many so I can enjoy them more, its frustrating at times, then all the parts etc and other stuff everywhere just struggle to work. really want to get them sorted and playable so can have a small meet sometime
5,332CR
I think this is likely ok. Often you'll find the earth just goes to the metalwork as it's there for safety, the electronics may 'float' the 0V without tying it to earth anyway (or it's earthed in another place, like the monitor). It won't be needed as part of the control circuit and doesn't feature on the drive PCB circuit.
I presume it's the same on all these cabs and 0v isn't earthed at the PSU?
Bods said:
Without Bulbs in or connected
P4 Drive Signal switching from 0.7v to 10v and 5v to 10v on Transistor base
Output to Bulb 5v to 11v
Bulb in
P4 Drive and Transistor base 0.5v to 3.2v so no output as transistor then doing nothing
What confused me is the input to this pcb, as manual shows it connected to the smaller transformer 560-5077 and sure that says 2.5 amp 25v
yet in the machine i've metered it to the Big Transformer 560-5076 which is 10v AC and it comes direct off transformer before the fuse shown
So has someone messed with it and wired to wrong output. Bulbs are 12v 10w with 2 in parallel, does that make it 20w it's powering
That doesn't sound right for the transistor. I would have expected the base to follow the drive signal better than that - as if the base is shorted to the 10V rail and the output is open circuit.
I can't remember what I bought for Jim's repro. I think the original is a KSA473 and I grabbed something cheap from Farnell - I think it was this:
D45H11 Stmicroelectronics, Bipolar (BJT) Single Transistor, PNP, 80 V | Farnell
