Space Invaders Coin Mech
monsterman
3CR
Hi I've got a cocktail space invaders, its got one of the old 1980's coin mechs (Old 10p). anyone got any info on how it works, or how I can get a game credit, I think I read somewhere the big red button (service menu) gives a credit, but nothing happens, hence I can't play it at the moment, any links to mech guides would be appreciate as I have no idea.
muchas gracias
Dave
DanP
Administrator
2,232CR
When it was made I think it would have been an S1 coin mech. This is a simple mechanical mechanism where the coin passes through it (or not if it's the wrong coin type) and then pushes a wire connected to a switch. You can usually manually push that wire up and down to add credits.
HTH
Dan
monsterman
3CR
Yes thats exactly how it works, only problem is when I lift the wire nothing happens, I've tried jumping the spade connectors, still nothing happens, would it be something on the PCB to check then?
Dave
DanP
Administrator
2,232CR
You need to check the wires connect to where they should on the PCB. You might have a broken wire or perhaps the connector harness isn't making contact. There should be two wires from the coin switch, one should be 5v, the other 0v (or ground). Check the pinout for the SI boardset to find where the wires should connect to.
Setch
The nice ad-min
542CR
there should be a credit board on the service block by the red button, if this is not present/faulty it wont credit.. I am pretty sure the service button wont credit either unless 2 pins are joined.
monsterman
3CR
Hi folks here are some pics
thanks for getting back guys here's some pics, could it be a setting on the dip switches perhaps
Regards
Dave
bones
1,628CR
Hi again, I'll have a look in my one at the weekend,just to make sure your dip switch settings are not set in an invalid position,not sure why there's 3 wires on your coin switch but that might be the way it was done back then. Tbh if you could find the PCB linings you could try a jumper wire dabbing between 0v and the coin input thus bypassing the credit board entirely. This would prove it is a board fault or not. For future reference this PCB has a dip switch setting which stops the invaders from shooting ??
