Space invaders minus the invaders-solved.
Lurch666
21 (100%)
4,518CR
Just got an original space invaders and it's booting but on the game screen the invaders and shots are missing.
I'm assuming this is down to the shifter circuit on the daughterboard.
It looks like some of the chips in the shifter circuit are socketed so will swap them first.
Lurch6662020-06-06 11:06:18
Lurch666
21 (100%)
4,518CR
Since this board uses 9316 roms I've temp re-strapped it so I can use the 2716 test rom and indeed it shows a fault in the shifter.
It's just the bottom row of numbers that's incorrect so will have to see which part of the shifter circuit it corresponds to.
Lurch666
21 (100%)
4,518CR
Looks like I stand corrected.
This is what it looks like when the shifter is working BUT for some reason the test rom is seeing an error because if the shifter is fine it doesn't show this screen and just says 'shifter ok'
This is getting interesting.....
Lurch666
21 (100%)
4,518CR
And my invaders are back.
After lots of piggybacking and head scratching (I still couldn't fathom why the shifter test looked correct but still wasn't working properly) I was looking at the schematics this morning and noticed pin 6 of the top daughterboard connectors is connected to reset.
Now in the pinout I got from the net it states that pin 6 needs to be grounded or the game won't run but since my invaders was working albeit without the invaders I had just run a wire from GND to this pin as a test to see if it made any difference but it hadn't.
This morning after seeing where the reset was connected (the ls174 chips that are part of the shifter circuit) I connected my scope to it and found the GND connection I had made to it wasn't connecting properly and it was still floating.
I made a better connection so it was properly grounded and it then passed the shifter test.
I did a quick re-strapping so I could put the original roms in and now the invaders,bombs and shots are all present.
Now to tackle the sound-I haven't even wired it up for sound yet as I wanted to get the game working properly first.
69er
1,852CR
Good stuff ….. I know a little bit ( or did back in the conversion kit days of the mid 80s) but if you had been about in the early 80s I have had long time friends in Stoke and I am sure I would have been calling round at your house too...……… ON A REGULAR BASIS ………
its incredible how many faults get cured on ukvac these days that deemed a SI unserviceable back then.. I think tho the problem was the agents who sold and repaired them were more interested in selling new colour games ……. and could not be bothered with small owner/ single site ops against the buying power of big companies...………
we knew a guy at Hazel grove music in Stockport did a few repairs but when Stan McKenna from A.L.L took over sales he was very unwelcoming to one off casual customers more a big brewery suck !
69er2020-06-06 11:32:02
Lurch666
21 (100%)
4,518CR
I lived in the arcades in the 80's.
While other kids were drinking or hanging round the street my mates and I were going Newcastle ,Stoke and Hanley to find the latest games.
Back then we could never imagine owning these games and I wouldn't have thought I might get to the point where I could repair them.
So we might have bumped into each other back then or even spoke but my memory is so bad all I can remember is the games themselves.
Lurch666
21 (100%)
4,518CR
Controls and sound are all fine except the saucer sound.
So it looks like it might be the 76477 that needs replacing.
Will pull the chip and put a socket in then use the replacement I got for my cosmic invaders (that I have now converted to a lunar rescue).
The thing is when I got the replacement 76477 for my cosmic invaders it was the wrong size.
With help I was able to get an adaptor but would prefer this time to get the correct size.
Does anyone know of a reliable source of these chips that will fit a space invaders since on ebay or other places they rarely give out the dimensions of the chip?
