space invaders part 2
corn
26 (100%)
231CR
Picked this up at a bootfair yesterday for £100. Not had a chance to power it up yet but the seller said it had a monitor fault. Apparently it has two white lines across the screen.
Anyone had any experience fixing similar issues and know a good source for cocktail spares?
Was £100 a reasonable price?
mathj
499CR
100 quid is a bargain
looks complete should be a easy fix
the left hand side lock looks like its a bit bent though
I think I got a manual for one of them somewhere
corn
26 (100%)
231CR
Excellent. It was a bit of an impulse buy. The Mrs is away for a couple of days as of tomorrow so hopefully I will get some time to tinker. No doubt I will have a good few more questions!
Ace`
PlanB contributor #1
40 (100%)
4,030CR
Nice pick up, I've never seen a arcade cab at a boot sale before. I have picked up a couple pinball back box glasses though.
corn
26 (100%)
231CR
Powered it up tonight - I hear fans spinning and theres a thud from the amp/speaker so I guess that all works ok. Output to the monitor is as follows:
Any ideas where I start?
One thing I did notice ... the top PCB (Labeled "G") has a damaged track. Someone looks to have repaired it at some point (with some fine wire). However, one end of the wire they used to repair with is no longer attached. I'll try and work out where it was attached and re-solder it.
Does this look like a monitor fault or a fault with the PCB? The line on the monitor does change colours periodically, making me think the PCB might be ok and its a monitor fault?
mathj
499CR
looks like a possible monitor issue to me
try pushing the red button inside by the coin mech for a credit and hit start
does it make space invaders noises?
andrew96
899CR
the monitors got frame collapse, that will be a fault on the monitor.
the gameboard looks something like 'moonbase' to me which is similar to space invaders and suffers from the same troubles that half the sounds go missing!
andrew96
899CR
yes of course.
I did fix a moonbase tabletop about a year ago, that was tthe sound problems on the board, but i never had the monitor out.
If the monitor is a toei cm-c14 then its going to take a bit of faultfinding as it is all transistor based and not just one IC to replace.
whats your faultfinding skills like?
corn
26 (100%)
231CR
I've always avoided CRT's - scared of making the Mrs as a single mum! I've now got 3 machines with various monitor faults - been putting off discharging tubes for sometime now. Guess I should man up and give it a go though.
The monitor is labeled "TOEI" on the side. I'm guessing I'll need to get it pulled out and repaired by someone that knows what they are doing. As long as it isn't terminal and can be repaired I'm pretty happy.
andrew96
899CR
naa no need to man up, they can be scary stuff monitors! they are something to be careful of! with there high voltage and vacuum glass tubes there not the best thing to mess with!
ah i was right with TOEI then!! So it is likely you have a 'moonbase' unit! I have a manual for that!
leave the monitor OFF for a day or so, that will discharge alot of any high residue voltage, then follow something like this... there are a lot of videos on the internet!! just don't break the neck of the tube!!
http://www.youtube.com/watch?v=bDAiLtTDuf4
