I had to make up a couple of POR boards today so I documented it for future reference, hopefully it can make it a little easier for others.
The circuit is available in the pinout from the robotron-2084 website.
http://www.robotron-2084.co.uk/manuals/invaders/midway_space_invader_pinout.pdf
Components needed:
CD4049 IC
16 Pin IC Socket (optional)
10k 1/4W Resistor
220uF 16v Electrolytic Capacitor
Stripboard (min 8x8 matrix)
I've used a program called Schematic StripLay for the image below.
http://www.atarado.com/soft-circuit-editor-schematic-layout-design-free.html#
You need to cut the traces between the IC pins, see the 'X''s on the image below.
Solder the components in as shown above and that's it.
Supply +5v and Ground and the POR comes off Pin 2 on the IC.
This is what it should do if all goes correctly.
https://www.youtube.com/watch?v=8E2P-gv3Uas
This is what will happen if it all goes terribly wrong...
Kaizen0882017-03-25 03:16:14
Components needed:
CD4049 IC
10k 1/4W Resistor
