Has it ever worked for you ? Is this in it's original cab with original power supply ? It's just because this era taito boards have a ' power on reset ' feature built into the power supply connecting to the edge connector that needs overcoming to get it to boot up properly. Had it with a field goal PCB that had similar issues as with your screen. I was lucky in that it only required a momentary switch to sort it out but I believe SI part 2 requires a few components. A good way to tell is to short the tilt pin to 0v and see if the tilt text displays on the screen, if it does then it probably is just the POR missing.
