Space Invaders Reset Circuit
Judder
1,009CR
I'm sure this has been covered many times, and heck, I'm sure even I have replied about this many times, but is it possible to boot a Space Invaders by grounding the reset line on the CPU manually and then releasing, rather than building a circuit to do so?
I know believe that Space Invaders Deluxe has a watchdog circuit, which resets the CPU itself if it isn't running, which is why those boards can just have the reset pin on the daughter board grounded, and they boot just fine
The reasons for asking is I have two spare board sets I am testing:
SIDelux boots fine with reset pin 6 on the daughter board connected to ground
SI just sits there with reset pin 6 on the daughter board connected to ground
Thanks!
Ace`
PlanB contributor #1
40 (100%)
4,038CR
I am going from memory so correct me if I am wrong but you can ground the reset pin at the sound board which has the reset circuit (on regular and deluxe versions) or force the reset pin high at the cpu if the reset circuit isn't working.
