Speakers
Rawsome
lost my cab cherry
72CR
Hey guys, just a question regarding sound for a cab. Again, still in the design stages presently. It will be for Mame but a Nintendo cab (scratch built, so no classic cabs will be slain in the process), same design as DK but...putting an additional speaker hole at the front. What is the best way to go with speakers? I've been told to grab pc speakers and de-case...also been told to splice car speakers together as another option. Any ideas? All input will be greatly appreciated!
Thanks,
Rory
RaveN
1,325CR
Call me a snob, but PC speakers in a cab is just wrong, don't they usually have something like 2" drivers? The people that do that seem to be the type to gaffa tape in LCD monitors into their cabs as well.
It's dead simple to wire up say a 4watt IC yourself, but if you're really not comfortable with electronics then there's always something like -> http://www.ebay.co.uk/itm/ARCADE-MACHINE-SOUND-SPEAKER-AMPLIFIER-WITH-PCB-MOUNTING-FEET-/370883473267?pt=UK_Video_Games_Coin_Operated_MJ&hash=item565a60af73
(although there's no info on the IC used).
Then just buy whatever size speakers you need, get fullrange (yeah car speakers are a good fit, as long as the IC is fine with 4ohms).
RaveN2013-11-09 22:29:22
  • Like
Reactions: trm
Rawsome
lost my cab cherry
72CR
Would that device allow me to attach an external sub woofer if I so choose to do so?Rawsome2013-11-09 23:38:20
RaveN
1,325CR
Not really. Potentially yes, it all depends on how you wire your speakers to get the current draw right, and whether your sub has a low-pass filter built in.
You can wire speakers in parallel or in series to control the overall load on the amp.
Andy
Rawsome
lost my cab cherry
72CR
Actually that device is mono. Think I will splice a good quality 2.1 pc sub setup with car speakers. Seems to be what most people are suggesting. Easy to do and good sound quality too.Rawsome2013-11-11 15:58:22
